Intel® Makers
9881 Discussions
Joule fails to boot after several successful boots
MDavi21
I recently got an Intel Joule 570x development kit and I noticed that often it hangs on booting. I've noticed after being unplugged it usually boots successfully a few times.
After a few reboots from the OS (I use Ubuntu 16.04), the board will not boot at all. From the serial connection it stops at
Board Name = Joule DVT3
MRC REVISION ID 1.52.27
MMRC REVISION ID 1.09
And does not display anything past that. I usually have to unplug the device and plug it back in but sometimes that doesn't even work. I've tried unplugging all peripherals with no luck. And this behavior doesn't seem to be systematic in that it can happen when being plugged in (cold boot), or from an OS reboot.
My best guess so far is that 1) my power adapter I ordered from Amazon might not be very stable, 2) there is a bios problem, or 3) there is a hardware problem with my board.
Any thoughts?
FGold
New Contributor II
I am also running Ubuntu.
Do not see this issue, you are describing.
Some ideas, to possibly isolate the issue.
Some ideas (my test setup):
verify the Intel Joule SOM is firmly installed on the TuChuck Development board
verify the heat sink is installed (is system getting hot?)
remove the micro SD Card if it is not being used
connect HDMI video to display
Connect USB serial Bridge (Hyper-terminal 115KB 8 N 1)
Connect USB hub with (Mouse and keyboard)
Notification with LEDs:
MAIN PWR LED is active when power is supplied
LEDS (Green) GPIO100 - on, delay 500ms, GPIO101 - on, delay 500ms, GPIO102- on, delay 500ms, all off (walking LED test) on bootup.
fourth LED GPIO103 is active when system BIOS Boot options can be selected.
Also the Blue wireless LEDs flicker on power up.
Scenario # 1)
For power try: plug-in USB 3.0 Type C connector (which provides power), and hyperterminal displays boot process.
and see if this is more reliable as a power up.
Scenario # 2)
plug-in Wall Wart (which provides power), and hyper-terminal displays boot process.
I am using the wall wart from the Intel Edison Kit: MOSO - MSP-C2000IC12.0-24W-zz
0.8A max, output 12V 2A
MDavi21
Hey thanks for the reply. Unfortunately, no luck resolving this. Here are some observations I made:
- I tried powering it through the USB-C port. Things seemed to be working but eventually it did start hanging again. I have not observed the system hanging when powered on the first time after being off for a while (hour or two).
- I am fairly confident it's not a thermal issue. There are times when it is booted and running software and the heatsink is noticeably warm and everything is fine. When it hangs on boot, the heatsink is usually cooler. I realize that's not a rigorous test, but I still think I'd be observing something like random shutdowns if the SoM was overheating. Also, the SoM was pre-seated on the development board and isn't noticeably loose.
- When it hangs, the Power and GP100 LED are on, no others are. Additionally, the blue wireless LED does not flash when it hangs. Often times when it does successfully boot, it prints the board name, MRC and MMRC revision, and BIOS ID twice; and sometimes it doesn't.
- This is also not limited to running Ubuntu, I observed this same behavior when I had Windows IoT installed.
- I think I mentioned this, but this behavior is also independent of peripherals (I've tried various configurations of USB devices - keyboard and flash drive, and micro-hdmi connector for a display). I currently only have the USB-C cable plugged in for power, and a micro-USB cable to attach my computer for access to the hyper-terminal. Also, I have removed the MicroSD card with no change.
At this point I am fairly sure it's a hardware issue and may have to see if I can return it for a replacement.
Thanks again for your feedback. If you have any other ideas, please let me know!
FGold
New Contributor II
The following is an interesting bread crumb:
"When it hangs, the Power and GP100 LED are on, no others are."
And may lead to where in the boot process the system is having issues (halting).
I am not sure aware of a boot-up state diagram which discusses the LED notification status. Maybe Intel can shed some light on this process.
Also I am not sure if you stated whether or not you are running (or have upgraded) to the new BIOS.
This does sound like it maybe an intermittent HW issue.
based on this issue, is it possible to get:
Open-source UEFI-compliant BIOS for the Intel Joule.
I did not find this with searches on the web: Does anyone know where the link is to this source code?
MDavi21
Hey,
I have updated my BIOS to the latest version on Intel's site (found in their user guide). I'd be interested in seeing their BIOS code as well if it is open-source.
I have submitted a support ticket and plan on just replacing the device to resolve this issue. It's pretty clear this behavior is not something that should happen under common configurations (including mine) and there isn't much else I can look at to debug.
Thanks again
Community Manager
Hi Medavies,
I believe we've already contacted you via email. Thank you for letting us know that you opened an email ticket. Feel free to ask any other question you may have in there.
-Pablo
FDogg
New Contributor II
Hi, what was the resolution to this, if any? I have the same thing, it randomly hangs on boot and it's really irritating. Unplugging the power doesn't always help and it seems random. I don't think it's hardware as it works perfectly otherwise, ditto thermal.
MAlde3
what was the solution for this case?
I have exactly the same problem.
regards,
Community Manager
Thank you for your interest in our Intel products.
Please make sure you have updated your BIOS to the latest version.
You can find the guide here: https://software.intel.com/en-us/flashing-the-bios-on-joule
If it was already updated, try reflashing the board.
Hope this helps.
Octavian
MAlde3
Hello Octavian,
I tried updating BIOS many times, it's still stuck at the same point.
This is what I get when I try updating (note that I don't get "Clearing NvStorage"):
And this is what I get on the serial port after updating:
It's stuck here, it does not boot and I can't go to BIOS settings.
Community Manager
Hello, Michael
Could you please try to update the BIOS using the command below?
Please use the "clear" parameter as there may be an incompatibility issue between the old bios setup variables and the new one.
"Flash.bat -clear Joule_C0-X64-Release-1J2-Public_DNX.bin"
Alexandra
Mustafa_A_Intel
Hello Alexandra,
I am getting another error from Flash.bat (both with and without clear parameter)
C:\Users\maldemix\Desktop\joule-firmware-2017-06-26-1J2-public (1)\DNX>Flash.bat -clear Joule_C0-X64-Release-1J2-Public_DNX.bin
Intel(R) Flash.bat version # 1.1.15
\DN was unexpected at this time.
I started the board in DNX mode (please see the attached screenshot)
The result is same after starting the terminal as an administrator.
Mustafa_A_Intel
I discovered that the problem was the folder name. After extracting the zip file to another folder, it worked.
Community Manager
Hello Michael,
Thank you for contacting Intel Technical Support.
Your request has been received and is currently being investigated.
We will get back to you as soon as possible.
Octavian
