Intel® Makers
9881 Discussions
KS0108 display driver porting from STM32
mgolu
New Contributor II
Hi all,
As in subjest I have graphic display ABG128064H05-YHY-R-01 based on KS0108 driver. I found driver on STM32 for this display but I want to port it into D2000 platform. I want to ask about two functions GLCD_ReadStatus and GLCD_WriteCommand because I'm not sure how they should looks like in D2000. Maybe someone have any idea ?
link to lbr for STM32: http://en.radzio.dxp.pl/ks0108/ks0108-stm32.rar http://en.radzio.dxp.pl/ks0108/ks0108-stm32.rar
Oryginal function body looks as below:
// Read Status byte from specified controller (0-2)
unsigned char GLCD_ReadStatus(unsigned char controller)
unsigned char status;
//GPIO_StructInit(&GPIO_InitStructure);
//GPIO_InitStructure.GPIO_Pin = 0xFF << KS0108_D0; //pin
//GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //pullup
qm_pmux_input_en (const qm_pin_id_t pin, const bool enable); //Enable input for a pin in the pin mux controller.
qm_pmux_pullup_en (const qm_pin_id_t pin, const bool enable); //Enable pullup for a pin in the pin mux controller.
//GPIO_Init(KS0108_PORT, &GPIO_InitStructure);
qm_gpio_set_config(&GPIO_InitStructure);
GPIO_SetBits(KS0108_PORT, KS0108_RW);
GPIO_ResetBits(KS0108_PORT, KS0108_RS);
GLCD_EnableController(controller);
GLCD_Delay();
GPIO_SetBits(KS0108_PORT, KS0108_EN);
GLCD_Delay();
status = ((GPIO_ReadInputData(KS0108_PORT) >> KS0108_D0) & 0xFF);
GPIO_ResetBits(KS0108_PORT, KS0108_EN);
GLCD_DisableController(controller);
return status;
// Write command to specified controller
void GLCD_WriteCommand(unsigned char commandToWrite, unsigned char controller)
while(GLCD_ReadStatus(controller)&DISPLAY_STATUS_BUSY);
GPIO_InitStructure.GPIO_Pin = (0xFF << KS0108_D0);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_ResetBits(KS0108_PORT, KS0108_RS | KS0108_RW);
GLCD_Delay();
GLCD_Delay();
GPIO_SetBits(KS0108_PORT, (commandToWrite << KS0108_D0));
commandToWrite ^= 0xFF;
GPIO_ResetBits(KS0108_PORT, (commandToWrite << KS0108_D0));
GLCD_Delay();
GLCD_Delay();
GLCD_Delay();
I connect it into D2000 board as below:
# include "qm_pinmux.h"
//Data bus - lines
# define LCD_DB0 QM_PIN_ID_6
# define LCD_DB1 QM_PIN_ID_7
# define LCD_DB2 QM_PIN_ID_2
# define LCD_DB3 QM_PIN_ID_5
# define LCD_DB4 QM_PIN_ID_10
# define LCD_DB5 QM_PIN_ID_11
# define LCD_DB6 QM_PIN_ID_12
# define LCD_DB7 QM_PIN_ID_13
//Data port
# define KS0108_PORT QM_GPIO_0
//Control Lines
# define KS0108_CS1 QM_PIN_ID_16
# define KS0108_CS2 QM_PIN_ID_18
# define KS0108_RST QM_PIN_ID_17
# define KS0108_RW QM_PIN_ID_0
# define KS0108_RS QM_PIN_ID_24
# define KS0108_EN QM_PIN_ID_9
# define KS0108_D0 0
# define DISPLAY_STATUS_BUSY 0x80
//User button
# define USER_BUTTON_IN QM_PIN_ID_2
extern unsigned char screen_x;
extern unsigned char screen_y;
extern int qm_gpio_clear_pin();
extern int qm_gpio_set_pin();
Community Manager
Hi Mark_kram,
Thanks for reaching out.
Did you check the http://https//downloadcenter.intel.com/download/25619/Intel-Quark-Microcontroller-Software-Interface Intel® Quark™ Microcontroller Software Interface? I think that it can help you to set the GPIOs in the right way to use your display with the D2000 platform.
I hope you find it helpful.
Have a nice day.
-Leonardo
Community Manager
Hi Mark_kram,
Have a nice day.
-Leonardo
