Community
cancel
Showing results for
Search instead for
Did you mean:
FDano
Keeps Losing Ability to Click With ANY Keyboard
Sometimes I have to restart several times or even unplug it to get the mouse "click" function to work (Bluetooth, Wifi, & app to no avail). When I mouse over objects they don't even appear to highlight when this happens, yet I can move the cursor no problem. Needless to say it's very annoying. Also, on start sometimes the start image before the login gets "sticky" where I can't type and the image&# 127; can be pulled down from the top like a shade over the logon screen... Any help would be greatly appreciated!
STK1AW32SC
Running all the latest drivers and BIOS (maybe that's the problem?)
Community Manager
Hi InfoSysLib,
We would need to narrow down the issue, let start verifying the BIOS and drivers versions. The latest BIOS is 0024 and latest System-on-a-Chip (SOC) Driver Package Version: 01.28.2016. Also it is very important to install the wireless and Bluetooth drivers.
Drivers:
https://downloadcenter.intel.com/product/91065/Intel-Compute-Stick-STK1AW32SC https://downloadcenter.intel.com/product/91065/Intel-Compute-Stick-STK1AW32SC
BIOS:
Then, it is recommended to verify if your Bluetooth keyboard battery has enough power.
At task manager check how many applications are working at the same time; applications slower down the stick performance.
Mike C
FDano
I can do better. See attached for my entire SysInfo file...
FDano
you guys were quick between BIOS updates. Just installed 24. Hope that does the trick!
Community Manager
Hi InfoSysLib,
I would be waiting your answer.
Mike C
FDano
No luck Mike, had to restart three times just to type this...
Community Manager
Hi InfoSysLib,
I suggest you to recover the operating system. Keep tapping F8 while booting the system.
Mike C
FDano
This is very frustrating... It didn't work. It's even worse now with the window shade effect I was talking about so I can't even log in most of the time. Should I try reverting to the last BIOS? Thanks!
Community Manager
Hi InfoSysLib,
I am following up your case. Let me know if previous BIOS version solves the problem.
Mike C
FDano
Actually, I think the latest graphics driver fixed the issue. It seems to be much more stable since I installed it. Thanks, Mike.
Community Manager
Hi InfoSysLib,
Thank you for your update. I am glad it is working better now.
Mike C
