Intel® Makers
9868 Discussions
LIbiio for edison
SRasa
Valued Contributor I
I posted on MRAA github for changing the ADC frequency but they suggested to use libiio. So is it possible to use libiio with edison arduino breakout board. And how shall I get 8khx adc frequency using libiio?
Diego_V_Intel
Hello Sriranjan,
I'm not familiar with this library. I did a quick research and found that the Libiio library is described here: https://wiki.analog.com/resources/tools-software/linux-software/libiio What is libiio? [Analog Devices Wiki]. The source code is here: https://github.com/analogdevicesinc/libiio analogdevicesinc/libiio · GitHub. You should try to build it for Edison and install it from the source code. Maybe you can post a request in this thread to include this library in the Edison repo and install it from there.
Diego.
Diego_V_Intel
Hello Sriranjan,
Diego.
