Intel® Makers
9874 Discussions
LVDS interface and wired ethernet
RPrei
i start to develop an iot device with joule. Now, i have two questions:
Is it possible to connect an LVDS display to the joule?
Are there any recommendations how to extend the joule with a wired ethernet interface? An external device such an usb to eth converter won't be a solution.
Many thanks, rico
JWenZ
http://www.baidu.com/link?url=gtWn5cDgCwCSOZijxotuT1JeexRU3cRonisrfnvlRbgtzp4UcXp_Em4IujDcP7xAleGR5j... Low Power HDMI to LVDS Display Bridge ADV7613
LAN7500 is a Hi-Speed USB 2.0 to 10/100/1000 Gigabit Ethernet controller
RPrei
Thanks. I will give it a try.
Community Manager
Hi Rico,
For Ethernet, not so long ago I was reading about a SPI to Ethernet module that might be of help, you can check its datasheet in here https://www.sparkfun.com/datasheets/DevTools/WIZnet/DEV-09473-Datasheet_V_1.1.pdf https://www.sparkfun.com/datasheets/DevTools/WIZnet/DEV-09473-Datasheet_V_1.1.pdf. I've never tested it before, but you can give it a try or check similar devices.
-Pablo
