Intel® Makers
9881 Discussions
Latest Core Libs
GStev2
The latest version of corelibs from https://github.com/01org/corelibs-arduino101 GitHub - 01org/corelibs-arduino101 doesnt seem to work right. Regardless of the script, nothing will compile with:
exec: "C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\Intel\\tools\\arduino101load\\1.6.9+1.28/arduino101load": file does not exist
Error compiling for board Arduino/Genuino 101.
This folder does exist, so I'm not sure the problem?
Community Manager
Hi Zapbbx,
Thank you for contacting us.
I tested the latest version, and yes, it doesn't work. But, I was checking the README and it says that the contents of this repo is distributed through releases in Arduino IDE. (Tools > Board > Boards Manager > Intel Curie Boards by Intel). I think that it is the stable version.
The README also says that If you wish to use the latest untested changes, follow some instructions. And the last sentence says: "Future upgrades may fail since the internal contents were modified by hand. In order to recover, shut down the IDE, delete the entire Arduino15 directory, then restart the IDE." So, yes it can fail because it is untested.
Have a nice day.
Leonardo R.
Community Manager
Hi Zapbbx,
Have a nice day.
Leonardo R.
