Community
cancel
Showing results for
Search instead for
Did you mean:
Weining_L_Intel
Latest cross compile toolchain(glibc) for quark doesn't work
Hi, all
I met some problems when using the self-built cross compile toolchain(glibc) for Quak. Can any help? Thanks!
From this site https://downloadcenter.intel.com/download/23197/Intel-Quark-BSP Download Intel® Quark™ BSP I get Board_Support_Package_Sources_for_Intel_Quark_v1.2.0.7z and Quark_BSP_BuildGuide_329687_009.pdf.
Following the build guide, I have suceessfully built out the cross compile toolchain installer(iot-devkit-glibc-x86_64-image-full-i586-toolchain-1.7.2.sh) on my Ubuntu-12.04 machine by "bitbake image-full" and "bitbake image-full -c populate_sdk".
But, it failed when I try to compile/link some program, who call the 'fputc' or 'fgetc' methods, using this toolchain.
// test1.c
# include
int main () {
fputc('a', stdout);
printf ("hello world! \n");
return 0;
In a new terminal window, source the environment setup script and compile test1.c. A link error occurs like this:
shaka@shaka-VirtualBox:~/test$ source /opt/iot-devkit/1.7.2/environment-setup-i586-poky-linux
shaka@shaka-VirtualBox:~/test$ $CC test1.c
/tmp/cctVzDzW.o: In function `main':
test1.c:(.text+0x50): undefined reference to `__fputc_unlocked'
collect2: error: ld returned 1 exit status
From google I got this explain https://www.uclibc.org/FAQ.html# miscompile https://www.uclibc.org/FAQ.html# miscompile saying that:
My package builds fine but link fails with errors like "undefined reference to __fputc_unlocked", who do I blame?!
This error crops up when a build system mixes system headers (say glibc) with the target headers (say uClibc). Make sure your build system is not including extraneous include options (-I) and double check that it is using the correct compiler. Many build systems incorrectly force things like -I/usr/include or -I/usr/local/include or -I${prefix}/include (which usually just expands to -I/usr/include)
It seems that the cross toolchain mixes glibc and uclibc. To prove this I wrote another program:
// test2.c
# include
int main () {
# ifdef __UCLIBC__
printf (" __UCLIBC__ is defined. \n");
# endif
return 0;
Compile test2.c with the cross toolchain and run on the Galileo Gen1 board. I got the output "__UCLIBC__ is defined.". So I think there is something wrong with the toolchain. The header file /opt/iot-devkit/1.7.2/sysroots/i586-poky-linux/usr/include/stdio.h has been attached for your reference. I doubt this file is not for glibc but for uclibc.
And, what's more:
If I source the file environment-setup-i586-poky-linux which is generated by "bitbake image-full" and "bitbake meta-ide-support", anything will be OK. No link error for test1.c and no output when running test2.
Is there anyone know what cause this issue and how to fix? Thanks!
(BTW, I have tried both 32 bit and 64 bit machine to built the toolchain and the issue exist all the same.)
Sergio_A_Intel
We will investigate and post a reply soon. We will update the case when we have more information.
Sergio
Weining_L_Intel
Thanks for your reply, Sergio.
Weining
Sergio_A_Intel
It looks like an issue with the header file. Which board are you using? We ran some tests and BSP source 1.0.6 from https://github.com/01org/Galileo-Runtime 01org/Galileo-Runtime does not have this issue. If you are using a Galileo I'd suggest you to use this package that has been tested with the Galileo.
Let us know your results.
Sergio
Sergio_A_Intel
Were you able to run the tests we recommended? Do you still need help with this thread?
Sergio
Weining_L_Intel
Hi Sergio,
Sorry for the late reply due to the Chinese New Year holiday. I'm using the Galileo Gen1 board and Board_Support_Package_Sources_for_Intel_Quark_v1.2.0.7z downloaded from https://downloadcenter.intel.com/download/23197/Intel-Quark-BSP Download Intel® Quark™ BSP. But I found that the version has been upgraded to 1.2.1.7 which I have not tried. Is the BSP 1.0.6 you mentioned at https://github.com/01org/Galileo-Runtime GitHub - 01org/Galileo-Runtime an older version? (I have not tried.) Is it an eglibc or uclibc toolchain?
Weining
Sergio_A_Intel
Yes, BSP 1.0.6 is an older version. If you look at the link we provided you'll find a link to the User Guide. At the end of section 7 you'll find information on how to build an eglibc image.
I haven't tried with 1.2.1.7 version either, but give it a try and let us know your results as well as with BSP 1.0.6. You can see more information on BSP 1.2.1.7 here https://downloadmirror.intel.com/23197/eng/X1000_BSP_BuildGuide.pdf https://downloadmirror.intel.com/23197/eng/X1000_BSP_BuildGuide.pdf
Sergio
Weining_L_Intel
One of my colleague just tried BSP 1.2.1.7 and the same issue exists. With limit time, we decide to use the toolchain environment setup script generated by "bitbake meta-ide-support" on the build machine. It is possible that BSP 1.0.6 works but we have not enough time to try.
Thanks for your time and I will close this post.
Weining
