Community
cancel
Showing results for
Search instead for
Did you mean:
MMich23
Linux image - npm command
Jump to solution
Hi support,
I have recently downloaded and wrote latest image (iot-devkit-prof-dev-image-galileo-20160606) from your website to my Galileo gen 2 board, but Im unable to use npm command... Is there a way to make it work - how to install the module?
Thanks for your advices
Community Manager
Hi autocontlab,
You have to download the packages from the following repository: http://iotdk.intel.com/repos/3.5/iotdk/galileo/i586/. To do this you can use opkg, so follow the next steps:
echo "src npm http://iotdk.intel.com/repos/3.5/iotdk/galileo/i586/" > /etc/opkg/iotdk.conf opkg update opkg install nodejs opkg install nodejs-npm
I hope this works for you, let me know if you have a problem with it.
-Leonardo
Community Manager
Hi autocontlab,
-Leonardo
Community Manager
Hi autocontlab,
Did you successfully install the packages? Are you able to use the npm command now?
Let us know if you have another problem.
-Leonardo
MMich23
Hi there, yes I did, thanks for your help.
Community Manager
Hi Autocontlab,
That's awesome! Thank you so much for letting us know.
Have a nice day.
-Leonardo
