Intel® Makers
9881 Discussions
Linux kernel 3.16.0-30 on Galileo Gen 2
JJonn
Hey everybody,
I have a small project where I am required to interface with a piece of touch foil. This foil was intended to be used with a desktop operating system, and the drivers I have are for kernel version 3.16.0-30. I have both 32 and 64 bit versions of the drivers. If I put debian on an SD card, would I be able to get this version of the kernel on the galileo through the normal repositories? If not, I assume I can compile it myself, although I'm certain that it would take a good amount of time. Also, the drivers I was given state that they are for ubuntu 14.04.02. I'd assume that these drivers would work with debian, since ubuntu is based on debian after all. Is this project possible with the galileo, or will I need to search for something else? Thanks.
Community Manager
It should be possible to build, however there are some considerations. The BSP of the Galileo doesn't include kernel 3.16. To add kernel 3.16 you'd need to create the recipes and check its functionality.
Another option would be to create kernel 3.16.0-30 using the sources from kernel.org but you'd have to import the OS. There aren't any guides to do this, since this kernel is not supported.
There are some threads in the community that discuss using a Debian image with the Galileo that you might find useful.
You can also look at
https://engage.intel.com/community/es/galileo/centro-de-aprendizaje/video-tutoriales/blog/2015/01/20... https://engage.intel.com/community/es/galileo/centro-de-aprendizaje/video-tutoriales/blog/2015/01/20...
http://allynh.com/blog/installing-debian-on-the-intel-galileo/ http://allynh.com/blog/installing-debian-on-the-intel-galileo/
Sergio
Community Manager
Sergio
