Intel® Makers
9868 Discussions
Linux kernel intel_mid question
Ster1
When I read the kernel changes by intel for Edison including intel_mid module, I see a lot of references to rpmsg.
Sounds like chip-to-chip communication mechanism. Question is, can I do that from user space or from command line? That would make it easy for me to test different things.
Thanks for your help.
Carlos_M_Intel
Hi stixter,
Which image are you using?
What changes do you want to do?
Have you tried in /sys/bus/rpmsg/drivers/intel_mid_rpmsg?
If you are not able to do changes in /sys for the rpmsg you will need to do the changes while building the image, this is because the rpmsg framework is related with kernel drivers. Another way is to install/create an API for rpmsg messages:
https://www.kernel.org/doc/Documentation/remoteproc.txt https://www.kernel.org/doc/Documentation/remoteproc.txt
https://www.kernel.org/doc/Documentation/rpmsg.txt https://www.kernel.org/doc/Documentation/rpmsg.txt
I hope this helps,
Charlie
Carlos_M_Intel
Hi stixter,
I hope this helps,
Charlie
