Intel® Makers
Linux on USB?
wcaro
Intel gentlemen, is there any way to boot Linux from USB, not from the SD card?
Community Manager
Hi Wilson,
Thank you for contacting us again!
Regarding your question, I've never tried this and I haven't seen any similar case in the Community, so I can't tell you for sure if it works or not. You could try to interrupt the boot sequence at start up and check if the USB partition is available as a part of boot options (honestly, I believe this is not the case but you could give it a try). You'll need to be connected through serial to check the boot process and to be able to stop it.
-Pablo
Community Manager
Hi Wilson,
We are wondering if you've been able to check our first post. Do you still have questions regarding the Galileo board?
-Pablo
