Community
cancel
Showing results for
Search instead for
Did you mean:
MTroj
Linux timer interval
Hello I want to run a timer with interval of 5 ms. I created a Linux timer and when a sigalrm_handler is called I'm checking elapsed time from a previous call. I'm getting times like: 4163, 4422, 4266, 4443, 4470 4503, 4288 microseconds when I want intervals to be about 5000 microseconds with a least possible error. Here is my code:
# include
# include
# include
# include
static int time_count;
static int counter;
struct itimerval timer={0};
void sigalrm_handler(int signum)
Serial.print("SIGALRM received, time: ");
Serial.println(micros()-time_count);
time_count=micros();
counter++;
if(counter > 20) {
timer.it_interval.tv_usec = 0;
timer.it_value.tv_sec = 0;
setitimer(ITIMER_REAL, &timer, NULL);
void setup() {
// put your setup code here, to run once:
Serial.begin(9600);
/* Initial timeout value */
timer.it_value.tv_sec = 1;
/* We want a repetitive timer */
timer.it_interval.tv_usec = 5000;
/* Register Signal handler
* And register for periodic timer with Kernel*/
signal(SIGALRM, &sigalrm_handler);
time_count = micros();
Community Manager
While I am not an expert on these matters, I believe that timing at the microsecond level is impractical for the stated operating system. I had similar timing challenges in using the DHTXX (temperature, humidity) sensors in any practical manner.
Regards.
Community Manager
Hello Michal,
Thank you for your interest in the Intel Edison board.
Unfortunately, we cannot comment or debug your code.
However, Edison is not running a real time OS and so the desired time precision (ms) may not be possible.
Octavian
Community Manager
Hello Michal,
Do you require any more assistance with this issue?
Octavian
MTroj
I have made it by creating a function that tuns in a separate thread and in a loop it has a delay providing by a micros() function.
FerryT
Valued Contributor I
Matha is right. Under load you might get 100ms error. Try f.i. running iperf simultaneously with your code.
With a preempt_rt version of the kernel you might achieve 100us or so.
Nevertheless it is strange that you measure less then 5ms, the latencies should be causing longer periods not shorter.
I have a piece of code that transmits data on fixed intervals. I use timerfd_create(CLOCK_REALTIME, 0) to create file descriptor containing timer events, then select() on the fd. This works for me (and even better on preempt_rt). If you're interested: https://github.com/htot/hs_uart/blob/master/main.c hs_uart/main.c at master · htot/hs_uart · GitHub from line # 147
