https://software.intel.com/en-us/node/545143# getting_scripts_onto_board Installing the MCU SDK | Intel® Developer Zone cites some port configuration scripts. As the procedure states this is supposed to work on Windows but what about Linux? I did not manage to find appropriate shell scripts under the link. Please check!
Hi mdw,
You should download the files from the Download page, https://software.intel.com/en-us/iot/hardware/edison/downloads https://software.intel.com/en-us/iot/hardware/edison/downloads. Under "MCU SDK" you should see a "Scripts" section, those are the files. Once you have them, you should be able to copy them to the board using SCP, you can find a guide for this in here: https://software.intel.com/en-us/articles/intel-iot-platforms-file-transfer-for-linux-using-scp https://software.intel.com/en-us/articles/intel-iot-platforms-file-transfer-for-linux-using-scp. Then, using the chmod command you can make the files executable.
Pablo
Hi mdw,
Pablo
