Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
MCU SDK x64 bit and x32 bit Windows Links Broken
Jump to solution
I've found that the following link: http://downloadmirror.intel.com/24910/eng/edison-mcusdk-win64-1.0.10.zip http://downloadmirror.intel.com/24910/eng/edison-mcusdk-win64-1.0.10.zip which can be accessed from the Microcontroller (MCU) SDK portion of the download page here: https://software.intel.com/en-us/iot/hardware/edison/downloads https://software.intel.com/en-us/iot/hardware/edison/downloads appears to have been broken the last couple days. Would it be possible to get this link corrected?
Mike
Accepted Solutions
Highlighted
Re: MCU SDK x64 bit and x32 bit Windows Links Broken
Jump to solution
Thank you for reporting this, we will pass this email to the proper team for handling. This issue seems to be intermittent though, I just tried to download it and the download started correctly so I'll suggest you to try again in a couple of minutes. Nevertheless we will inform the proper team about this.
Thanks and regards,
Sergio
Highlighted
Jump to solution
Thanks and regards,
Sergio
