Intel® Makers
9880 Discussions
MCU i2c problems
Community Manager
I'm trying to port my i2c sensor reading code from mraa to mcu and I'm having some difficulties. I'm using Arduino breakout board. I followed the instructions here https://software.intel.com/en-us/node/557354# Reading_the_value_of_an_I2C_device_and_sending_it_back_to_the_host Using the MCU SDK and API: Code examples | Intel® Software. After Edison boots I run init_i2c8.sh to enable i2c8. The script gives me these errors, which are not mentioned in the example:
/home/root/mcu_stuff/init_i2c8.sh: line 3: echo: write error: Device or resource busy
/home/root/mcu_stuff/init_i2c8.sh: line 4: echo: write error: Device or resource busy
/home/root/mcu_stuff/init_i2c8.sh: line 9: echo: write error: Device or resource busy
/home/root/mcu_stuff/init_i2c8.sh: line 10: echo: write error: Device or resource busy
After that I start reading of the i2c data on mcu, however it hangs on the first attempt to read something:
debug_print(DBG_INFO, "LSM303_init() checking who_am_i\n");
unsigned char id;
int res = i2c_read(LSM303_acc_address, LSM303_WHO_AM_I, &id, 1); //hangs here
debug_print(DBG_INFO, "LSM303_init() who_am_i: %d\n", id);
I would like to add that nearly identical code using mraa works flawlessly:
i2c->address(acc_address);
unsigned char id = i2c->readReg(WHO_AM_I); //I get correct device id
cout << "LSM303_init() who_am_i: " << (int) id << endl;
I couldn't find much information about i2c8 in edison hardware guides besides that I need to have it muxed in order to use i2c on mcu.
According to the Edison Board configuration tool I'm running the latest firmware.
Community Manager
Hi Piotrek,
Thanks for using Intel Edison, we'll try to help you with this.
We would like to know if you loaded the SDK scripts as it is mentioned in the section Loading the MCU SDK scripts onto your board, in this link https://software.intel.com/en-us/node/545143 https://software.intel.com/en-us/node/545143,
Additionally, as you mentioned, we must program pin muxing before using I2C from MCU, we configured the I2C-8 running the script init_i2c8.sh (https://software.intel.com/en-us/node/557356 https://software.intel.com/en-us/node/557356). This message /home/root/mcu_stuff/init_i2c8.sh: line 3: echo: write error: Device or resource busy indicates that the pin has been exported before, so it was already in the export file and didn't indicate any error.
Also, we would like to know a little bit more information, which sensor are you using and its configuration? This is in order to help you.
-Yermi
Community Manager
Hi Piotrek,
I would like to know if you have any updates or questions. Just let us know and we'll help.
-Yermi
