Community
cancel
Showing results for
Search instead for
Did you mean:
JRoew
MCU is not working on many Edisons
Jump to solution
I have seen the MCU stop responding on many different Edisons.
As a test, I try to run:
cat /sys/devices/platform/intel_mcu/fw_version
When the MCU on the Edison works I get the response:
1.0.10
But on many Edisons I get a read error:
cat: read error: Operation not permitted
The kernel log (dmesg) shows the following error:
intel_psh_ipc 0000:00:16.0: ia2psh channel 2 is always busy!
The problem persists even after a reboot. I am seeing this problem on 80 out of 130 Edisons.
This problem is a major issue because I need put the Edison to sleep to save power and have the MCU wake up the Edison later. If the MCU does not work then the Edison will never be woken up.
Diego_V_Intel
Hello JimR,
Have you checked the image version of the Edisons? Run the following command in both Edisons to check the version: configure_edison --version
From your description, the image version might be the cause of the issue. If so, re-flashing the modules might fix it.
Diego.
Diego_V_Intel
Hello JimR,
Diego.
JRoew
I am using a custom image built from SDK release 2.1. I have removed the oobe package, so configure_edison is not available.
What modules are you talking about reflashing?
I am using the mcu_fw_loader systemd service to load my MCU image from /lib/firmware/intel_mcu.bin
JRoew
Thanks, I realized that my upgrade process has been updating the boot and rootfs partitions, but was not upgrading the mmcblk0boot0 and mmcblk0boot1 partitions, so the low level firmware used for the system and MCU was not getting updated. After upgrading those partitions, the MCU now works on several of the Edisons that I tested.
