I'm trying to find out the cause of my MCU project crashing, I assume, it's ViperOS task, but I'm unable to find any help with the documentation provided by the MCU SDK as to how to determine what the source of the problem is.
Pretty much what I have right now is my MCU project waits on receiving a "go" command from Linux side and then setups up GPIO pins direction and just acks any further "go" commands:
# include "mcu_api.h"
# include "mcu_errno.h"
# include
# include
typedef enum eGPIOs
GPIO_15 = 15, //
GPIO_44 = 44, // IR sensor
GPIO_45 = 45, // button
GPIO_46 = 46, //
GPIO_47 = 47, //
GPIO_48 = 48, //
GPIO_49 = 49 //
} eGPIOs;
// GPIOs to be configured for interrupts
typedef struct tGPIOInt
int gpio;
int mode;
uint32_t timestamp; // time since last interrupt, non-zero when pending
} tGPIOInt;
tGPIOInt GPIOs_Int[] =
// { GPIO_15, 0, 0 }, //
{ GPIO_44, 0, 0 }, // IR sensor
{ GPIO_45, 0, 0 }, // button
{ GPIO_46, 0, 0 }, //
{ GPIO_47, 0, 0 }, //
{ GPIO_48, 0, 0 }, //
{ GPIO_49, 0, 0 } //
# define GPIO_INT_COUNT (sizeof(GPIOs_Int) / sizeof(GPIOs_Int[0]))
uint8_t buffer[8];
void mcu_main()
int size;
debug_print(DBG_INFO, "waiting on go...\n");
// wait for host processor to be ready for us to run
while (1)
size = host_receive(buffer, sizeof(buffer));
if((size > 0) && memmem(buffer, size, "go\n", 3))
break;
// check again in 1 second
mcu_sleep(100);
debug_print(DBG_INFO, "go command received! Setting up GPIOs.\n");
mcu_sleep(50); // 500ms wait
// setup GPIO interrupts
for(size_t i=0; i
gpio_setup(GPIOs_Int[i].gpio, 0);
debug_print(DBG_INFO, "GPIOs setup, registering ISRs.\n");
// do nothing for now
// loop forever
while (1)
// wake-up every 100ms and check if any interrupts fired
mcu_sleep(10 /* X 10ms */);
// see if host processor is wanting our attention
debug_print(DBG_INFO, "acknowledging go command.\n");
The problem is that as soon as I give the go command:
# echo "go" > /dev/ttymcu0
I get this dumped into the USB serial console (Note: Neither the faulting address nor context ID ever changes between program code changes):
***** Unhandled exception/interrupt occurred! *****
Current context ID = 0xff10fb34
Faulting instruction address = 0x00000023
Fatal task error! Aborting task.
And all I get is this from the debug serial:
# cat /dev/ttymcu1
( INFO): waiting on go...
So it appears to crash before the second debug_print() is reached. I put a mcu_sleep() for half a second after each debug_print() just in case that pipe was buffered and didn't get flushed to Linux side until after a couple of ViperOS task context switches.
Anybody from Intel have any ideas as to how to fix this crashing issue?
I looked through the MCU API documentation section and I believe the error is in the host_receive function. Can you put a print_debug inside the while() loop to see if it provides additional information?
Is your issue similar to this /message/369567# 369567 https://communities.intel.com/message/369567# 369567 ?
Sergio
Do you still need assistance with this thread, were you able to fix the crashing issue?
-Sergio
