Community
cancel
Showing results for
Search instead for
Did you mean:
FFahd
MLX90614
Jump to solution
I've recently acquired an MLX90614 sensor pre-attached to a breakout board to which i soldered headers for SCL,SCA,VCC and GND. I'm using the Galileo with the Arduino IDE. I'm also using Adafruit's MLX90614 library. I've attached SCL to A5 and SDA to A4. My particular sensor with the breakout board apparently supports both 3.3V and 5V. There is a LED indicator on the sensor so it is getting power fine. I'm using the example Adafruit code for it. It compiles and uploads fine. However I'm getting constant useless values. The serial monitor is reporting:
Ambient = 1037.55*C Object = 1037.55*C
Ambient = 1899.59*F Object = 1899.59*F
This is a library example for the MLX90614 Temp Sensor
Designed specifically to work with the MLX90614 sensors in the
adafruit shop
----> https://www.adafruit.com/products/1748
----> https://www.adafruit.com/products/1749
These sensors use I2C to communicate, 2 pins are required to
interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
# include
# include
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
void setup() {
Serial.begin(9600);
Serial.println("Adafruit MLX90614 test");
mlx.begin();
void loop() {
Serial.print("Ambient = "); Serial.print(mlx.readAmbientTempC());
Serial.print("*C\tObject = "); Serial.print(mlx.readObjectTempC()); Serial.println("*C");
Serial.print("Ambient = "); Serial.print(mlx.readAmbientTempF());
Serial.print("*F\tObject = "); Serial.print(mlx.readObjectTempF()); Serial.println("*F");
Serial.println();
delay(500);
Adafruit: https://learn.adafruit.com/using-melexis-mlx90614-non-contact-sensors/wiring-and-test https://learn.adafruit.com/using-melexis-mlx90614-non-contact-sensors/wiring-and-test
Community Manager
Hi Fshiwani,
Some time ago another user reported issues with this sensor when using it with Galileo. As you can see in this thread: https://communities.intel.com/message/222253# 222253 https://communities.intel.com/message/222253# 222253, it's a speed issue with the Galileo's I/Os. The sketch seems to be fine, however the issue is not at software level but at hardware level.
You can also try to upload the sketch attached below (I2CScanDevices) just to check if your device is at least recognized by the board. If it's recognized, then the issue could be related to the example code or the library used and it might be fixed, but if the device is not recognized, I'm afraid the issue is because of the Galileo's I/O.
Hope you find this information useful.
-Diego
FTinetti
Honored Contributor I
Hi FShiwani,
The wire library does not work in Intel Galileo IIRC...
Are you powering the module with 3.3 or 5v? About
Take into account that a LED usually indicates "some" power, not necessarilly enough for the module. I've used a HC-05 and it failed with 3.3v even when the LED was on.
Fernando.
FFahd
I tried with 5V as well, same issue. Are you sure the wire library doesn't work, I've seen some threads saying it does work
https://social.msdn.microsoft.com/Forums/windowshardware/en-US/ec16ad66-1e67-4de4-92e4-a69a1212c8d9/... Looking for I2C example
Are there any alternatives to the wire library for I2C communication with the Galileo?
Community Manager
Hi Fshiwani,
-Diego
Community Manager
Hello Fshiwani,
I'd like to know if you have updates on this.
-Diego
