Intel® Makers
9881 Discussions
MPU9250 Connection Failed
YLu12
The IMU 10DOF is connected to the Intel Edison Arduino board.I use the code provided by Grove - IMU 10DOF Wiki. How to handle the problem "MPU9250 connection failed"?
The hardware connection is as the picture shows:
And the library is put into Arduino IDE:
The result is as follows:
In addition,the data did't update. Have you ever met this problems?
Diego_V_Intel
Hello 朝露映曦,
I found another thread where you asked this same question. In fact, I answered you there explaining that the issue might be caused by the compatibility between the library and the Edison architecture:
Also, I suggested you a couple of alternatives that you might want to try in order to use the MPU-9250 and the BMP180. These alternatives were posted in your older thread. Please check it.
Diego.
Diego_V_Intel
Hello 朝露映曦,
Diego.
