Community
cancel
Showing results for
Search instead for
Did you mean:
LGran3
MPlayer Not Installing
Yocto 2.1
159.dev version
/thread/55692 Alex_T's repo
Having gone through the bluetooth guide and tutorials, it utilizes MPlayer, but when I try to install it, it's not successful. Have been trying to installing successfully for days and have gone through this /thread/75748?start=0&tstart=0 correct answer, which lead me to this /thread/93267 correct answer. Every time I try to install MPlayer-1.1.1, I get this error:
make: install: Command not found
Makefile:910: recipe for target 'install-dirs' failed
make: *** [install-dirs] Error 127
Everything in the linked to solutions install correctly and are up to date, except for libavahi-client-dev. That gives me the error that there is no such package and I have not been able to find it to download online. I also read in the second correct answer that the author was able to install and get MPlayer to run without installing libavahi-client-dev. What else can it be? This is very frustrating. I am currently looking for alternative ways to play music through bluetooth communication. Any suggestions are greatly appreciated.
Sergio_A_Intel
Is that the complete error log? What are the contents of /etc/opkg/base-feeds.conf? Do you have the command make installed?
Run:
opkg install make
opkg install packagegroup-core-buildessential
Let me know your results.
Sergio
LGran3
Hi Alvarado,
That is the complete error log, that snippet is the only error I get after make install has been compiling. The process stops and spits out that error.
I am using Alex-T's repo, as mentioned above, this is in the base-feeds.conf
src all http://repo.opkg.net/edison/repo/all http://repo.opkg.net/edison/repo/all
src edison http://repo.opkg.net/edison/repo/edison http://repo.opkg.net/edison/repo/edison
src core2-32 http://repo.opkg.net/edison/repo/core2-32 http://repo.opkg.net/edison/repo/core2-32
I'll install command make and recompile and install when I have a moment, it's a long process and has been put on hold as of now. Thank you!
Carlos_M_Intel
Hi postITnote,
Have you been able to install MPlayer in your board?
Charlie
