Intel® Makers
9881 Discussions
MRAA Library falling edge interrupt not proper work.
Community Manager
Hello everyone;
I made the one application based on switch . I want to configure switch as gpio_interrupt.
I had configure the IO4 as a interrupt for switch.
Below is my code.
# include
# include
char counter = 0;
void intrHandler(void *arg)
counter++;
// printf("C = %d\n",counter);
int main()
mraa_init();
mraa_gpio_context m_gpio;
m_gpio = mraa_gpio_init(4);
mraa_gpio_dir(m_gpio, MRAA_GPIO_IN);
mraa_gpio_mode(m_gpio,MRAA_GPIO_PULLUP);
mraa_gpio_isr(m_gpio, MRAA_GPIO_EDGE_FALLING, intrHandler, NULL);
sleep (20);
printf("outer_counter = %d\n",counter);
mraa_gpio_isr_exit(m_gpio);
mraa_gpio_close(m_gpio);
return 0;
I had check program with "MRAA_GPIO_EDGE_RISING" EDGE and its run fine and i get the 100% proper result.
but I had check program with "MRAA_GPIO_EDGE_FALLING" EDGE, it is run but result is not proper means the key press for single time and interrupt isr will call two time or random. its behaviour is random.
Please help me to solve my problem.
Thanks & Best Regards;
Nikunj Patel
TDzei
Dear Nikunj_Patel,
Why do you try to apply the output mode "MRAA_GPIO_PULLUP" on an input pin?
And, this works with the Arduino breakout board but not with the mini breakout board.
Community Manager
I have just use the initial pull up because my switch does not have pullup configuration.
Community Manager
Hi Nikunj_Patel,
I tested your code sending the signal of 5 V directly to the pin 4, it didn't run well because the noise was making a random behavior like you said, it happened on both edges (RISING and FALLING). So I tried to use a normal switch with a clean input signal and it worked perfectly (on both).
Personally, I would recommend you to try to use a filter to clean the signal to avoid any strange behavior. If you want to use a simple filter check this link: https://www.ikalogic.com/de-bouncing-circuits/.
I hope this information helps you.
-Leonardo
Community Manager
Hi Nikunj_Patel,
Was the information useful? Did you test the interrupts using a filter? Did it work?
Remember that we are here to help you. Have a nice day.
-Leonardo
Community Manager
Hello ;
We try lots but we can't set the right value of rc components.so the issue is not solve.
Can you share your schematic of switch?
Nikunj Patel
Community Manager
Hi Nikunj_Patel,
That's weird, like I told you I tested your code sending the signal of 5 V directly to the pin 4, it didn't run well because the noise was making a random behavior like you said, it happened on both edges (RISING and FALLING).
So I tried to use a switch but it didn't use a debouncing circuit, I recommended it to you because it could help you. About the switch that I used is the switch of the Grove Starter Kit ( http://wiki.seeedstudio.com/wiki/Grove_-_Starter_Kit_v3) and it worked perfectly (on both).
About the debouncing circuit, in the link that I suggested you in the last reply says that the good starting values for a general purpose de-bouncing circuit would be R1 = 10 KOhm and C1 = 100 nF ceramic capacitor.
If you still need help just let us know.
Have a nice day.
-Leonardo
Community Manager
Hello Leonardo;
Thank for your help;
We have solve the de-bounce problem using the 100K(Resistor) & 1UF (Capacitor) value.
mraa library included code fine work with IO0,IO1,IO3,IO5,IO6,IO9,IO12.
but still de-bounce issue occur on IO4,IO10,IO11,IO13. (2 event occur on falling edge).
also IO2 mraa code have segmentation fault with below logs.
open("/sys/bus/iio/devices/iio:device0/name", O_RDONLY) = 4
read(4, "adc1x8s102\n", 64) = 11
close(4) = 0
time([1475494559]) = 1475494559
send(3, "<141>Oct 3 11:35:59 libmraa[116"..., 100, MSG_NOSIGNAL) = 100
stat64("/sys/class/gpio/gpio35/", 0xbff38550) = -1 ENOENT (No such file or directory)
open("/sys/class/gpio/export", O_WRONLY) = 4
write(4, "35", 2) = 2
close(4) = 0
open("/sys/class/gpio/gpio35/value", O_RDWR) = 4
lseek(4, 0, SEEK_SET) = 0
write(4, "1", 1) = -1 EPERM (Operation not permitted)
close(4) = 0
send(3, "<139>Oct 3 11:35:59 libmraa[116"..., 63, MSG_NOSIGNAL) = 63
--- SIGSEGV {si_signo=SIGSEGV, si_code=SEGV_MAPERR, si_addr=0x14} ---
+++ killed by SIGSEGV +++
Segmentation fault
Please help us to solve the above issue.
Thanks & Best reagards;
Nikunj Patel
Community Manager
Hi Nikunj Patel,
That's weird, I tested your code with the pin 2 and I didn't get any errors (Look the photo).
As you can see in the image, I am using the pin 2 (m_gpio = mraa_gpio_init(4)). I compiled the code and I ran it without problems, and the button works perfectly.
I recommend you to try to flash the latest Edison image, and update the MRAA library to the version 1.3, and run the code again.
Let me know if you still have issues.
-Leonardo
Community Manager
Hello ;
Thanks for quick reply.
We are currently use the Intel Galileo rev 2 not Edison.
I have check with mraa 1.3 library and solve the issue of IO2.
Have you test these IO4,IO10,IO11,IO13 pins?
Thanks in advance.
Nikunj patel
Community Manager
Hi Nikunj_Patel,
We are going to move this case to the right forum (Galileo). About your case, it is weird that the debouncing circuit doesn't work in some pins. Let me do some more tests and I'll let you know when I get the results
I appreciate your patience.
-Leonardo
Community Manager
Hi Nikunj_Patel,
We're still working on this, I'll let you know when I have updates of this.
I really appreciate your patience.
-Leonardo
Community Manager
Hi Nikunj_Patel,
We did some tests, and we found out that all the pins are working fine. In the tests that we did we used the latest Galileo Image 201606081532, and we updated MRAA to 1.4.0.
The code that we ran is the example in the MRAA repository ( https://github.com/intel-iot-devkit/mraa/blob/master/examples/isr_pin6.c), we edited the file to use the falling edge interrupt.
We tested all the pins, and they worked without problems. So I recommend you to do the same with the example code, and let us know if you get the same results.
If you get the same results, that means that the error is in the software and it isn't in the hardware (Galileo board). In this case try to adapt your code to the example code to make sure that it works.
We will be waiting for your results.
Have a nice day.
-Leonardo
Community Manager
Hello Leonardo;
We check on intel side but we cant find 201606081532 image so We check the iot-devkit-prof-dev-image-galileo-20160606.direct image from https://software.intel.com/galileo-image/latest https://software.intel.com/galileo-image/latest link and we updated MRAA to 1.4.0.
The code that we ran is the example in the MRAA repository (https://github.com/intel-iot-devkit/mraa/blob/master/examples/isr_pin6.c https://github.com/intel-iot-devkit/mraa/blob/master/examples/isr_pin6.c), we edited the file to use the falling edge interrupt and pin to 4/10/11.
but still issue is not solved.
please tell us the your switch configuration.
Thanks in advance.
Community Manager
Hi Nikunj_Patel,
It is the same image, if you write the command: cat /etc/version you will get the number 201606081532.
About the button that I'm using, it is the button of the http://wiki.seeedstudio.com/wiki/Grove_-_Starter_Kit_v3 Grove Starter Kit, so I'm not using any external circuit, and it works perfectly.
Have a nice day.
-Leonardo
Community Manager
Hello;
I have checked http://wiki.seeedstudio.com/wiki/Grove_-_Starter_Kit_v3 Grove Starter Kit switch configuration but it has pull down configuration.
can you know the result of all pins after testing with Rising edge interrupt mode ?
Thanks in advance.
Community Manager
Hi Nikunj_Patel,
We tested the three edge modes (Rising, Falling and Both) in all the pins, and they worked without problems. I'm not sure why you have this problem. It is weird.
Have you tried to debounce the input signal with software? It can be another solution that can be useful for you.
Have a nice day.
-Leonardo
Community Manager
Hi Nikunj_Patel,
I was wondering if you have updates about this.
Remember that we are here to help.
-Leonardo
Community Manager
Thanks for your support.
but still the issue is not solved.
Thanks for your help.
Community Manager
Hi Nikunj_Patel,
Well, that's weird. We already tested the pins and we didn't have issues.
Can you provide us any additional information that can be useful for further analysis?
Have a nice day.
-Leonardo
