Intel® Makers
9881 Discussions
MRAA Serial on tx en rx
BWill15
New Contributor II
I wrote code for setting up a serial communication on pins 0(RX) and 1(TX) using mraa.
import mraa as m
x = m.Uart(0)
x.setBaudRate(115200)
x.writeStr('Hello')
x.read(5)
Will this interfere with my connected FTDI cable?
Diego_V_Intel
Hello BrechtW,
No, it shouldn't interfere with the FTDI cable connected. The serial port used to access the terminal is different than the one used by MRAA (pins 0 and 1).
Diego.
Diego_V_Intel
Hello BrechtW,
Diego.
