Intel® Makers
9881 Discussions
Make-Run I/O Code for Linux Image
AGuil4
Hello everybody.
I have a question and do not know how to approach it.
I'm running on Intel Galileo gen1 an sd-image of Linux customized, so I communicate with it with ssh (Putty), specifically this:
https://github.com/xbolshe/galileo-custom-images/tree/master/iot_1.1.0_dirty_kernel_3.19.2 xbolshe/galileo-custom-images · GitHub
What I want is to schedule programs that work, for examplo, with the ports of input/output as it is programmed in Arduino IDE software:
like these:
https://learn.sparkfun.com/tutorials/galileo-experiment-guide/sik-galileo---part-4-driving-multiple-... Galileo Experiment Guide - learn.sparkfun.com
I know I can program directly with Linux commands and run .sh files, but that for commands that take into account the output ports and do not know how. For example, in Arduino IDE software program, save the program with a special extension and run Galileo through ssh as # vi test.sh
Can you recommend what I can do. What are my options?
Can you recommend manuals on programming that involves, for example, ports of entry and departure from the linux console ssh?
Ps: Some manual Galileo program from the Arduino software?
I hope you can help me.
Thank you very much in advance.
BR.
Antonio_Algaida
Sergio_A_Intel
If what you are looking is for a way to program that easily interfaces the I/O ports you can check MRAA. Libmraa is a C/C++ library with bindings to Python, Javascript and Java to interface with the I/O on Galileo.
Take a look at the MRAA website here http://iotdk.intel.com/docs/master/mraa/ mraa: Main Page
If you are looking for examples of the Arduino IDE then you can also check
Sergio
Sergio_A_Intel
Sergio
AGuil4
Oh yes, I am is what I wanted to refer. Thank you.
And if I can ask something else, you know any tutorial for Intel Galileo MRAA for beginners apart from the examples in their official website?
Thank you for responding.
A greeting.
BR. Antonio_Algaida.
Sergio_A_Intel
There's not a specific document or tutorial of mraa for beginners but there are several websites that might be helpful such as
https://github.com/intel-iot-devkit/mraa intel-iot-devkit/mraa · GitHub
http://iotdk.intel.com/docs/master/mraa/python/ Welcome to mraa's documentation! — mraa v0.8.0-18-g338feb2 documentation
Sergio
