Bought 12 of the win8.1 version. Have only been setup and running for less than 3 months. 5/12 faulty so far. Have been swapping them out with 2nd batch (newer pre-installed with win10) Only been running those in the last few weeks but since its the same hardware I'm fully expecting those to fail in the coming months as well.
From what I've seen the failures seem to be either looping through boot or unable to detect boot device, also had one that would get power but that's it. No picture, definitely wasn't booting with just no pic because wouldn't show on network when left powered on.
Anyone else experiencing unacceptable failure rates with these devices?
UPDATE: 2 more just failed today. Now at 7/12 faulty.
Hello DanielR34,
Thank you for joining the Intel communities.
Please try the following:
Update the Intel® Compute Stick BIOS; please download the latest BIOS version for this unit at:
https://downloadcenter.intel.com/download/25506/BIOS-Update-FCBYT10H-86A- Download BIOS Update [FCBYT10H.86A]
In this case I recommend doing a BIOS recovery and you can follow the steps at:
http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000005902.html Intel® Compute Stick BIOS Recovery Instructions
After that is done reset the system to factory defaults:
If anyone else is having this problem it will be appreciated if it can be posted here.
Ivan
We have seen a failure rate of about seven out of ten. All failures but one can be attributed to either windows updates or OS update to Win 10
This seem an absurd amount of work to revive a brand new product. Intel should allow re-imaging of the device and an override to turn OFF all windows updates. I started adding the following regedits to all new ones we buy:
Windows 10 updates stop
https://support.microsoft.com/en-us/kb/3080351 https://support.microsoft.com/en-us/kb/3080351
To block the upgrade to Windows 10 through Windows Update, specify the following registry value:
Subkey: HKLM\SOFTWARE\Policies\Microsoft\Windows\WindowsUpdate
DWORD value: DisableOSUpgrade = 1
For non-Enterprise versions of Windows, the notification icon can be suppressed through the Windows registry. To do this, set the following registry value:
Subkey: HKLM\Software\Policies\Microsoft\Windows\Gwx
DWORD value: DisableGwx = 1
I'm sorry for all the inconvenience this has cause to you all.
Some customers have had positive experience with the Intel® Compute stick, you can see it here:
/thread/96904 https://communities.intel.com/thread/96904
Intel and Microsoft are aware of the Windows 10 update issue and you can see more information at the following link:
/thread/93643?tstart=0 https://communities.intel.com/thread/93643?tstart=0
Ivan
Finally have a few of the faulty ones back in my possession and they take absolutely ages just to get to the bios or attempt doing a bios update. Looks like the built in storage is actually faulty in both the units I've checked over. BIOS appears to update but any attempt to image/recover has errors trying to access the storage device. Looks like I'll be sending a whole lot more back for warranty. Time to look for a different product I guess. No way I can rely on these devices.
I'm sorry for all the inconvenience this can cause to you all and I understand this can be frustrating.
I will report this failure rate with Intel® Compute Stick so we can try to get a better solution for you.
I apologize for this situation and I hope after the replacements you can get a better experience with this units.
Ivan
Hello All,
I work for Intel Customer Support and your feedback and comments were reported up and we hope replacements units wont exhibit this high failure rate.
I apologize for all the inconvenience caused.
Can you please help with tickets 254023 and 244347
I made a request to expedite resolution on these 2 Service Tickets.
Daniel, I am right there with you. I am seeing the same type of failure rates. I had started another post along the same lines as yours. I bought two to test with. Both have failed. In my case, both seem to have failed due to the Windows 10 update process. I'm trying to go through and do a manual recovery since the automatic recovery options are not working.
Intel has been sending out the new revised version that comes with Windows 10 preloaded. The new ones fail just like the others. We put them in service following the basic windows setup and find them in a state of "stalled" the screen will read something like "applying updates do not power off" , the things will stay that way indefinitely and never recover. We don't even load profiles of applications on the things. I assume that it's either lack of memory, lack of CPU or lack of storage that is causing them to fail right out of the box. We have started shipping them via USPS because it's gotten out of hand how many we've had to send back. So Intel if you are listening, do your own experiment: provision a new stick PC, (can't turn off updates) let it run. Watch it crash and never come back. FYI, recovery does NOT work.
On the one I own that did upgrade to Windows10 successfully, I have sent the "applying updates do not power off" stuck screen. I have also seen the 100% completed stuck screen. I was not sure if this was an issue on my end or not. I also purchased an HP Stream 13 as an alternative product to try out. I am interested in it since it has a scree, keyboard, hdmi port, and other stuff all together as well. The only problem I have had with the stream13 was the update to Windows 10. Once I went in and blew away the recovery part of the disk, Windows 10 had enough space to update and everything has been fine since. another option I am looking into is one of the small gigabyte ultracompact pc boxes. They are fairly small. I've used one of them at a customer and had no issues whatsoever. Granted, I put a 128 gig ssd in it instead of 32 gigs drive and 8 gigs instead of the 2 gigs, but I haven't had any issues there either.
One thing that I have found this morning is that updating the bios seems to make a world of difference. My devices were very early devices that I purchased via amazon. I futzed with them Sunday as well as first thing this morning. I finally decided to update the bios. Once I updated the bios, the Windows 10 update worked properly and the device seems to be much more stable. Granted, this is early in the update process. I've also updated windows to whatever the latest update is. I'm plugging along right now. We'll see how this goes over time.
I have two dead ones in the mail right now and a third on my desk stuck at "resetting 45%". Makes me crazy. Maybe Intel should slow down on these until they are stable.
Here is my story, I made the massive mistake of buying55 of these units. Various failures such as
Your pc encountered a problem
Windows Failed to start
A bootable device has not been detected
No Boot device
No amount of hitting the F button for windows repair will make it start repair. Most of these devices fail after trying to do windows updates. I reckon they are overheating during updates and crapping themselves. Boot devices pretty much flake out after this.
So far, I have 21 units out of 55 that have failed with the first 16 being RMA with my supplier. I want to abandon them and get a credit off Intel because it is wasting my time replacing them in the field. Costing me way more than what i am saving by using a cheaper smaller pc that even intel suggest is good for digital signage.
Please someone from Intel contact me. I am in Australia.
Jeremy
We are aware of the update issue and we are currently working with Microsoft to investigate a problem where the Windows® 10 Autumn Update causes the Intel® Compute Stick to fail.
You can see here:
http://www.intel.com/support/motherboards/desktop/stck1a32wfc/sb/CS-035870.htm?wapkw=stck1a32wfc Intel® Compute Stick STCK1A32WFC — Issue with Windows® 10 Autumn Update
We really apologize for this inconvenience and I hope you can have a better experience with the ones you still have.
There is Windows TH2 update available and you can see more information here:
http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000017933.html?wa... Windows® 10 Threshold 2 Update Guide for Intel® Compute Stick...
This website shows the Windows® 10 Threshold 2 Update Guide for Intel® Compute Stick.
