Intel® Makers
9881 Discussions
Matt's traceroute on edison
Community Manager
Hi, I've been trying to find solution, how to install Matt's traceroute on Edisons yocto, without results. I wan't to use Edison for network diagnostic.
Can someone help me with it?
Thx.
wilq
Pablo_M_Intel
Hi wilq,
Could you tell us what you have tried so far? Could you please share the steps that you're following that you're performing?
In case the package is not already in the http://repo.opkg.net/edison/repo/ AlexT repo, the standard steps would be to download the software from the developer's site using wget, then unzip the file, move to the recently unzipped folder and then run the make commands.
Now, probably you'll need to install some other dependencies to be able to use MTR, but I would suggest you to start with that.
Pablo
Pablo_M_Intel
Hi wilq,
Pablo
