Intel® Makers
9868 Discussions
Maximintergrated MAXREFDES117 with Intel Galileo Gen 1
pnguy22
I have the same problem this post /message/420514# 420514 MAXREFDES117 . However, I rewrite max30102.cpp using Wire for Galileo board. But, it can not write register address and data.
I have tried using Wire with my Arduino Uno board and it not working (It working fine with SoftI2Cmaster.h on Arduino Uno). I'm thinking MAXREFDES117 not support Wire library.
Please provide a solution in this case.
Here my result on Arduino Uno and Galileo:
max30102.cpp on Arduino Uno:
# include
# include "max30102.h"
# include "algorithm.h"
bool maxim_max30102_write_reg(uint8_t uch_addr, uint8_t uch_data)
* \brief Write a value to a MAX30102 register
* \par Details
* This function writes a value to a MAX30102 register
* \param[in] uch_addr - register address
* \param[in] uch_data - register data
* \retval true on success
if(!i2c_start(I2C_WRITE_ADDR))
return false;
if(!i2c_write(uch_addr))
return false;
if(!i2c_write(uch_data))
return false;
i2c_stop();
return true;
bool maxim_max30102_read_reg(uint8_t uch_addr, uint8_t *puch_data)
* \brief Read a MAX30102 register
* \par Details
* This function reads a MAX30102 register
* \param[out] puch_data - pointer that stores the register data
return false;
return false;
if(!i2c_rep_start(I2C_READ_ADDR))
return false;
*puch_data=i2c_read(true);
i2c_stop();
return true;
bool maxim_max30102_init()
* \brief Initialize the MAX30102
* \par Details
* This function initializes the MAX30102
* \param None
i2c_init();
if(!maxim_max30102_write_reg(REG_INTR_ENABLE_1,0xc0)) // INTR setting
return false;
if(!maxim_max30102_write_reg(REG_INTR_ENABLE_2,0x00))
return false;
if(!maxim_max30102_write_reg(REG_FIFO_WR_PTR,0x00)) //FIFO_WR_PTR[4:0]
return false;
if(!maxim_max30102_write_reg(REG_OVF_COUNTER,0x00)) //OVF_COUNTER[4:0]
return false;
if(!maxim_max30102_write_reg(REG_FIFO_RD_PTR,0x00)) //FIFO_RD_PTR[4:0]
return false;
if(!maxim_max30102_write_reg(REG_FIFO_CONFIG,0x4f)) //sample avg = 4, fifo rollover=false, fifo almost full = 17
return false;
if(!maxim_max30102_write_reg(REG_MODE_CONFIG,0x03)) //0x02 for Red only, 0x03 for SpO2 mode 0x07 multimode LED
return false;
if(!maxim_max30102_write_reg(REG_SPO2_CONFIG,0x27)) // SPO2_ADC range = 4096nA, SPO2 sample rate (100 Hz), LED pulseWidth (411uS)
return false;
if(!maxim_max30102_write_reg(REG_LED1_PA,0x24)) //Choose value for ~ 7mA for LED1
return false;
if(!maxim_max30102_write_reg(REG_LED2_PA,0x24)) // Choose value for ~ 7mA for LED2
return false;
if(!maxim_max30102_write_reg(REG_PILOT_PA,0x7f)) // Choose value for ~ 25mA for Pilot LED
return false;
return true;
# if defined(ARDUINO_AVR_UNO)
//Arduino Uno doesn't have enough SRAM to store 100 samples of IR led data and red led data in 32-bit format
//To solve this problem, 16-bit MSB of the sampled data will be truncated. Samples become 16-bit data.
bool maxim_max30102_read_fifo(uint16_t *pun_red_led, uint16_t *pun_ir_led)
# else
bool maxim_max30102_read_fifo(uint32_t *pun_red_led, uint32_t *pun_ir_led)
# endif
* \brief Read a set of samples from the MAX30102 FIFO register
* \par Details
* This function reads a set of samples from the MAX30102 FIFO register
* \param[out] *pun_red_led - pointer that stores the red LED reading data
* \param[out] *pun_ir_led - pointer that stores the IR LED reading data
uint32_t un_temp;
uint8_t uch_temp;
*pun_ir_led=0;
*pun_red_led=0;
maxim_max30102_read_reg(REG_INTR_STATUS_1, &uch_temp);
maxim_max30102_read_reg(REG_INTR_STATUS_2, &uch_temp);
return false;
if(!i2c_write(REG_FIFO_DATA))
return false;
return false;
un_temp=i2c_read(false);
un_temp<<=16;
*pun_red_led+=un_temp;
un_temp<<=8;
un_temp<<=16;
*pun_ir_led+=un_temp;
un_temp<<=8;
un_temp=i2c_read(true);
i2c_stop();
*pun_red_led&=0x03FFFF; //Mask MSB [23:18]
*pun_ir_led&=0x03FFFF; //Mask MSB [23:18]
re...
Community Manager
Hello phunguyen,
Thanks for reaching out!
Creating this sort of modifications to a library can prove quite challenging, therefore I understand this situation. I took a brief look at the modified version and I can't find the issue. So, my best suggestion is that you try an alternative method. Maxim Integrated provides a standard C++ library in https://developer.mbed.org/teams/Maxim-Integrated/code/RD117_MBED/, you could take this library and use it on the Linux side of Galileo, this might save you some time trying to debug the modified version of the Arduino library.
In fact the Arduino library is based on the Maxim Integrated C++ library, so, I believe it shouldn't that different to use.
I hope this helps.
-Peter.
pnguy22
Hi Peter,
Thank for your reply. I will try to use C++ library https://developer.mbed.org/teams/Maxim-Integrated/code/RD117_MBED/ R117_MBED .
Have nice day!
PhuNguyen
Community Manager
Let us know how it goes.
-Peter.
