Intel® Makers
9880 Discussions
Mi Intel stick no inicia con windows. Ya actualice el BIOS a 31 y no funciona ni en refresh no el repair. Que puedo hacer?
EScor
Amy_C_Intel
Hello, emscorza:
In this case I recommend doing a BIOS recovery and you can follow the steps at:
http://download.intel.com/support/motherboards/desktop/sb/recoveryupdateinstructions.pdf http://download.intel.com/support/motherboards/desktop/sb/recoveryupdateinstructions.pdf
After that is done, try to reset your system and follow these steps:
  1. Remove any SD card, if installed.
  2. Press F8 when you see this prompt during boot: F8 to Activate Windows 8.1* Recovery Mode.
  3. Select Troubleshoot.
  4. Select Reset your PC, then select Next.
  5. Select Just remove my files.
  6. Select Reset to start the restore process.
EScor
Hola ya hice esto pero al intentar el reset me dice que ha ocurrido un problema y no pudo reservar.
Gracias por la respeusta
Amy_C_Intel
My recommendation at this stage is to contact http://www.intel.com/content/www/us/en/support/contact-support.html Contact Support in order to check the replacement options for your Intel® Compute Stick.
Amy.
