Intel® Makers
9872 Discussions
Micro SD Card(Sandisk 16GB) Cannot Detect and Canot Bootable
ChunHuat_Y_Intel
I have Intel Compute Stick model STK1AW32SC which I am trying bootable using micro SD card, but result is unsuccessful.
Check in Bios Menu(F2), no micro SD card device detected, even USB already set enabled. Understand that this compute stick model already installed Windows 10 32bit OS.
Micro SD card
-Storage : 16GB
-Type : SDHC Class 10
-Brand : Sandisk
-Bootable micro SD card with Windows 10 32it OS.
-Bios flash to version 0035
-Bios cannot detect micro SD card device
-No issue for USB bootable can detect the device
Questions
1) Does Compute Stick support bootable micro SD card?
2) If yes, how to make it work, can provide instruction?
3) If no, any idea this feature will be implement in future? When release date?
Patrick Yeoh
AlHill
1) No
2) SD card is not bootable
3) Unknown
Doc
AlHill
1) No
3) Unknown
Doc
ChunHuat_Y_Intel
Doc,
So no feature request for enabling this SD card in bios menu?
Patrick
AlHill
Only one of the Intel Support Staff can answer that question. They will be responding to your question.
Doc
Community Manager
Hello gar\yeohchux,
Thank you for contacting the Intel community.
That is correct, there Micro SD card is no bootable with the Intel® Compute stick.
At this point, we don't have any information if this is going to be possible in the future with a new BIOS update, I cannot guarantee it. I'm sorry, for now I would not expect that to happen soon.
Ivan U.
ChunHuat_Y_Intel
Hi Ivan U,
Thanks for your advised.
You can close this case.
Patrick
Community Manager
You are more than welcome, and I'm sorry that this is not available right now.
Best wishes,
Ivan U.
