Community
cancel
Showing results for
Search instead for
Did you mean:
ABerg10
Mouse.h fatal error
hi,
I'm trying to do a mouse controller with the Joystick in Galileo gen 2, but when I'm using the mouse.h, I get this error:
arduino-1.6.7\libraries\Mouse\src/Mouse.h: fatal error HID.h: no such file directory.
I trying to downgrade the version of the environment, and to reinstall it, but it didnt solved it.
I also get into the dir and i saw that the file: HID.h is exist. But, I see that the path in the error msg has also a back slash:
\Mouse\src/Mouse.h... i think mybe this is the problem.
Eventually, I checked in the net, and i discover that the package unsupported in this board.
so i want to know if there is any replacement?
thanks,
Daniel94
FTinetti
Honored Contributor I
Hello Daniel94,
Are you using another design/sketch as an example or designing from scratch? I do not have any experience with joysticks, is it "standard" to handle joysticks via the mouse library?
Would you send some code?
I've not seen much change in supported libraries, so I think unsupported libraries would remain unsupported, but maybe I'm losing something.
Fernando.
ABerg10
Hi Fernando,
first I want to thank you for your help.
I can send you my code, but there is an website that show the code of the same program i want to do, and it quite similar to mine.
This is the link:
https://www.arduino.cc/en/Tutorial/JoystickMouseControl?action=sourceblock&num=1 https://www.arduino.cc/en/Tutorial/JoystickMouseControl?action=sourceblock&num=1
The code works for sure, but not on Galileo.
And if you want i can send also my code.
Daniel94
FTinetti
daniel94 wrote:
Hi Fernando,
This is the link:
Daniel94
I see, thanks, it is enough with this code example.
I think that
"Controls the mouse from a joystick on an Arduino Leonardo, Micro or Due."
(copied from the URL you sent) implies a high likelihood that the example will not work on an Intel Galileo... maybe the Due similarity would help, but I think that the underlying Intel Galileo Linux (Yocto) operating system would not help in reusing this example.
Looking for examples of joystick control in Intel Galileo I found several "overkilling" examples (at least for me)... and many of them directly imply to use Debian, specific shields, etc... (some of them in Spanish...)
https://software.intel.com/en-us/articles/robot-arm https://software.intel.com/en-us/articles/robot-arm
/thread/54936?start=0&tstart=0 https://communities.intel.com/thread/54936?start=0&tstart=0
https://www.youtube.com/watch?v=CBRE00s4q58 Programming with the Intel Galileo - Joystick Control - YouTube (and several related ones)
https://engage.intel.com/community/es/galileo/centro-de-aprendizaje/video-tutoriales/blog/2015/01 Tutoriales : 2015 : January | Intel Engage
https://engage.intel.com/community/es/galileo/centro-de-aprendizaje/video-tutoriales/blog/2015/03 https://engage.intel.com/community/es/galileo/centro-de-aprendizaje/video-tutoriales/blog/2015/03
I think there should be some better/reduced example...
I would like to have time to experiment with this... please keep us/me posted if you advance
Fernando.
