Intel® Makers
9874 Discussions
My Compute Stick was working fine and now I get "No Signal" after "Retrieving Data". Have tried different HDMI ports and rebooting with the same result.
KZumw
Anyone else have this issue?
Allan_J_Intel1
Are you using any type of video HDMI adapter?
- Be sure you are using the AC power adapter plugged into a wall outlet; do not try powering the device from a USB port. We've seen odd boot issues when powering from USB.
- Before trying to access the recovery partition via the F8 key, make sure you do NOT have an SD card or a USB portable thumb drive attached to the Compute Stick. We've seen these cause recovery failures.
In case you need warranty replacement you will need to create a web ticket here:
http://www.intel.com/content/www/us/en/support/contact-support.html Contact Support
Allan.
Community Manager
Please confirm if you still need assistance from the Intel support team.
Allan.
