Community
cancel
Showing results for
Search instead for
Did you mean:
LBoec
My compute stick (windows 8.1) is not abel to recover after a not successful automatical update to Windows 10!
BBoot process asks for storage device which is attached properly
Community Manager
Hello, Willig8tes:
Please try the following;
  1. Remove any SD card, if installed.
  2. Press F8 when you see this prompt during boot: F8 to Activate Windows 8.1* Recovery Mode.
  3. Select Troubleshoot.
  4. Select Reset your PC, then select Next.
  5. Select Just remove my files.
  6. Select Reset to start the restore process.
If you want to update your Intel® Compute Stick to Windows® 10 I would recommend checking this link http://www.intel.com/content/www/us/en/support/boards-and-kits/intel-compute-stick/000016164.html Windows® 10 Update Instructions.
Amy.
Community Manager
Hello, /message/391361 Willig8tes:
Is your Intel® Compute Stick working? Did my suggestion work?
Let me know your findings.
Amy.
