Community
cancel
Showing results for
Search instead for
Did you mean:
IIstv
NFS server on Edison
I'd like to mount Edison directories into my Ubuntu14.04's fs. I found some discussions about how to make the Edison an nfs client, but I suppose, I need the opposite.
I found a note about reconfiguring the kernel, so I bitbaked the 3.0 image, and started menuconfig, only to find nfs had been enabled in the file system section already.
Yet, when I add a line in my /etc/exports file on the Edison, reboot, and try to mount it from my desktop, it will time out in about a minute with no connection. (Network connection works, I can ssh to the Edison.)
Could somebody please help me to proceed?
Tags (1)
Community Manager
What steps have you done so far? According to /message/263910# 263910 https://communities.intel.com/message/263910# 263910 , only NFS client is enabled by default, not NFS server. Have you made any configurations on the client side? Do you have any type of security on the Edison that deny any other devices that try to connect?
Looking at some information on NFS, it's recommended to configure /etc/hosts.allow besides /etc/exports. Have you tried to configure it? You can see more information here http://www.tldp.org/HOWTO/NFS-HOWTO/server.html http://www.tldp.org/HOWTO/NFS-HOWTO/server.html
-Sergio
IIstv
I reconfigured the Edison kernel. Marked NFS V3 (it had been selected already) and NFS V4, saved the .config and rebuilt it.
It was not easy, because the instructions I have found are quite outdated. I used these two links:
http://shawnhymel.com/724/creating-a-custom-linux-kernel-for-the-edison-yocto-2-1/ Creating a Custom Linux Kernel for the Edison (release 2.1) | Shawn Hymel
https://software.intel.com/en-us/node/593593 IoT - Customizing the Linux* Kernel | Intel® Software
(Many thanks for the authors)
Then with scp I copied
ldlinux.c32 ldlinux.sys syslinux.cfgvmlinuz
(and the kernel modules) onto the Edison, and restarted it.
However I still cannot see NFS server working on the Edison. I tried rpcinfo -p and it says:
root@edison1:~# rpcinfo -p
program vers proto port service
100000 4 tcp 111 portmapper
100000 3 tcp 111 portmapper
100000 2 tcp 111 portmapper
100000 4 udp 111 portmapper
100000 3 udp 111 portmapper
100000 2 udp 111 portmapper
I am not very much into rpc, but I think it should list nfs here.
I also tried showmount from my client:
showmount -a 192.168.80.201
clnt_create: RPC: Program not registered
I looked at the link you had given, and added my host ip address in /etc/hosts.allow. (Though the link says /etc/hosts.allow and /etc/hosts/deny cause a global permission/restriction situation in the system, and I think we hit wall, way before that.)
I use my office server from this laptop, so it is most likey configured well as a client.
Community Manager
It seems the issue is in the kernel configuration. Can you list all the steps you made to configure it so we can try to replicate? Please be as detailed as possible.
-Sergio
Community Manager
Were you able to configure the NFS server on the Edison?
-Sergio
IIstv
Sorry, it took long to get away from my everyday project. I knew reproduction of the kernel konfiguration would take long, so I had to wait for a weekend to reproduce the process. Unfortunately in the meantime the Edison Yocto source on the download site has changed, and this time I could not even build it anymore. Here is what I've done so far:
I used the following links:
https://software.intel.com/en-us/node/593593 https://software.intel.com/en-us/node/593593
http://shawnhymel.com/585/creating-a-custom-linux-kernel-for-the-edison/ http://shawnhymel.com/585/creating-a-custom-linux-kernel-for-the-edison/
http://shawnhymel.com/724/creating-a-custom-linux-kernel-for-the-edison-yocto-2-1/ http://shawnhymel.com/724/creating-a-custom-linux-kernel-for-the-edison-yocto-2-1/
(The "Download" chapter of the last site contains the list of tools to download, but I had had these already.)
Download
Downloaded the complete image of the Edison File system from here:
https://software.intel.com/en-us/iot/hardware/edison/downloads https://software.intel.com/en-us/iot/hardware/edison/downloads
Link: Intel Edison Board Firmware Software Release 3.5 / Sources - GPL/LGPL source files
The download site redirected me to here:
http://iotdk.intel.com/src/3.5/edison/ http://iotdk.intel.com/src/3.5/edison/
where the file to download was: iot-devkit-yp-poky-edison-20160606.zip . Not the same image I had got the last time I downloaded it.
I downloaded and extracted it in my Edison_BSP directory. For simplicity I mounted it to /mnt/edison.
From here my directory tree goes like this:
/mnt─ edison
├── iot-devkit-yp-poky-edison-20160606
│ ├── iot-devkit-yp-poky-edison-20160606
│ │ ├── build_edison
│ │ └── poky
│ └── README.edison
└── iot-devkit-yp-poky-edison-20160606.zip
Build
Further on I followed the instructions in README.edison:
cd iot-devkit-yp-poky-edison-20160606/poky/
source oe-init-build-env ../build_edison/
bitbake edison-image u-boot
Entered the "poky" folder, and executed:
In the poky folder I started the build process with:
After some 3 hours the process stopped with Error messages:
ERROR: Function failed: do_compile (log file is located at /mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/build_edison/tmp/work/core2-32-poky-linux/oobe/1.2.0-r0/temp/log.do_compile.928)
ERROR: Logfile of failure stored in: /mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/build_edison/tmp/work/core2-32-poky-linux/oobe/1.2.0-r0/temp/log.do_compile.928
and
ERROR: Task 1181 (/mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/build_edison/../poky/meta-intel-edison/meta-intel-edison-distro/recipes-support/oobe/oobe_1.2.0.bb, do_compile) failed with exit code '1'
ERROR: Function failed: do_compile (log file is located at /mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/build_edison/tmp/work/core2-32-poky-linux/xdk-daemon/0.1.4-r0/temp/log.do_compile.935)
The error message was about a permission problem, of npm. I tried to run log.do_compile.928 manually, but I got the same error. After some search I found that the access to npm working directory should be reconfigured to a local directory. I tried it, when finally I got a more descriptive message, stating that in fact npm was not installed. So
sudo apt-get install npm
and started the bitbake over again.
However after a few hours I get another error message:
DEBUG: Executing python function sstate_task_prefunc
DEBUG: Python function sstate_task_prefunc finished
DEBUG: Executing python function do_package_qa
NOTE: DO PACKAGE QA
DEBUG: Executing python function read_subpackage_metadata
DEBUG: Python function read_subpackage_metadata finished
ERROR: QA Issue: xdk-daemon: The compile log indicates that host include and/or library paths were used.
Please check the log '/mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/build_edison/tmp/work/core2-32-poky-linux/xdk-daemon/0.1.4-r0/temp/log.do_compile' for more information. [compile-host-path]
I found it was not a good idea to restart an interrupted build process, so I made a clean install again, and started it - this time with npm having been installed, but the process stopped with the same error.
I am not into bitbake, and I have no idea how and where could I modify the configuration so that the includes and library paths would be the right ones.
Community Manager
Have you already seen Section 4 of the Edison BSP http://www.intel.com/content/www/us/en/support/boards-and-kits/000005616.html http://www.intel.com/content/www/us/en/support/boards-and-kits/000005616.html ? Section 4 is about creating custom images. It includes steps how to add libraries to the correct files. It also has steps to add lib PNG to an image. Look for the NFS server package in http://recipes.yoctoproject.org/rrs/recipes/2.2/M2/ http://recipes.yoctoproject.org/rrs/recipes/2.2/M2/ and follow the guide to have that package added to your image.
-Sergio
FDomí1
Hi everybody,
Has anyone solved this problem yet? I am trying to build the iot-devkit-yp-poky-edison-20160606 image for the Edison also. My host is a Ubuntu 14 LTS machine. After running
and waiting for a few hours, I get this error:
Please check the log '/home/federico/yocto_linux_stuff/edison/iot-devkit-yp-poky-edison-20160606/build_edison/tmp/work/core2-32-poky-linux/xdk-daemon/0.1.4-r0/temp/log.do_compile' for more information. [compile-host-path]
ERROR: QA Issue: iotkit-comm-js: The compile log indicates that host include and/or library paths were used.
Please check the log '/home/federico/yocto_linux_stuff/edison/iot-devkit-yp-poky-edison-20160606/build_edison/tmp/work/core2-32-poky-linux/iotkit-comm-js/0.2.0-r0/temp/log.do_compile' for more information. [compile-host-path]
WARNING: QA Issue: iotkit-comm-js-mdns requires libdns_sd.so, but no providers in its RDEPENDS [file-rdeps]
WARNING: QA Issue: ELF binary '/home/federico/yocto_linux_stuff/edison/iot-devkit-yp-poky-edison-20160606/build_edison/tmp/work/core2-32-poky-linux/xdk-daemon/0.1.4-r0/packages-split/xdk-daemon/opt/xdk-daemon/current/node_modules/mdns/build/Release/obj.target/dns_sd_bindings.node' has relocations in .text [textrel]
WARNING: QA Issue: xdk-daemon requires libdns_sd.so, but no providers in its RDEPENDS [file-rdeps]
ERROR: QA run found fatal errors. Please consider fixing them.
ERROR: Function failed: do_package_qa
ERROR: Logfile of failure stored in: /home/federico/yocto_linux_stuff/edison/iot-devkit-yp-poky-edison-20160606/build_edison/tmp/work/core2-32-poky-linux/iotkit-comm-js/0.2.0-r0/temp/log.do_package_qa.6774
ERROR: Task 1117 (/home/federico/yocto_linux_stuff/edison/iot-devkit-yp-poky-edison-20160606/build_edison/../poky/meta-intel-iot-middleware/recipes-devtools/iotkit-comm-js/iotkit-comm-js_0.2.0.bb, do_package_qa) failed with exit code '1'
ERROR: Logfile of failure stored in: /home/federico/yocto_linux_stuff/edison/iot-devkit-yp-poky-edison-20160606/build_edison/tmp/work/core2-32-poky-linux/xdk-daemon/0.1.4-r0/temp/log.do_package_qa.6773
ERROR: Task 1171 (/home/federico/yocto_linux_stuff/edison/iot-devkit-yp-poky-edison-20160606/build_edison/../poky/meta-intel-iot-devkit/recipes-devtools/xdk-daemon/xdk-daemon_0.1.4.bb, do_package_qa) failed with exit code '1'
Looking at the log file that error points to, I find this:
cc1plus: warning: include location "/usr/include/nodejs/src" is unsafe for cross-compilation [-Wpoison-system-directories]
cc1plus: warning: include location "/usr/include/nodejs/deps/uv/include" is unsafe for cross-compilation [-Wpoison-system-directories]
cc1plus: warning: include location "/usr/include/nodejs/deps/v8/include" is unsafe for cross-compilation [-Wpoison-system-directories]
I haven't been able to fix this and I am stuck now unable to build this image. Any ideas how to fix it? Also, the link to the PDF here:
is broken.
Thanks in advance for your help.
Federico
FDomí1
UPDATE: If someone runs into the same problem, it helps if you clean the recipe cache with bitbake -c clean. For example, I ran:
bitbake -c clean xdk-daemon
bitbake -c clean iotkit-comm-js
and then restarted the process by running again:
and that fixed the problem in my case.
Cheers!
IIstv
Thanks fexadom, it is light in the tunnel. The minute I'll have 6 hours to spare, I'll try it.
I read all over the BSP document (http://www.intel.com/content/www/us/en/support/boards-and-kits/000005616.html http://www.intel.com/content/www/us/en/support/boards-and-kits/000005616.html) , but it did not help me to solve the problem. The build process in it, is different from what the README recommends, but the process ends with error messages again. It is quite frustrating, because the first version I could build flawlessly.
IIstv
Nop,
Still errors:
Please check the log '/mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/build_edison/tmp/work/core2-32-poky-linux/iotkit-comm-js/0.2.0-r0/temp/log.do_compile' for more information. [compile-host-path]
WARNING: QA Issue: post-install requires /bin/bash, but no providers in its RDEPENDS [file-rdeps]
WARNING: QA Issue: systemd-kernel-install requires /bin/bash, but no providers in its RDEPENDS [file-rdeps]
ERROR: Logfile of failure stored in: /mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/build_edison/tmp/work/core2-32-poky-linux/iotkit-comm-js/0.2.0-r0/temp/log.do_package_qa.26439
ERROR: Task 1117 (/mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/build_edison/../poky/meta-intel-iot-middleware/recipes-devtools/iotkit-comm-js/iotkit-comm-js_0.2.0.bb, do_package_qa) failed with exit code '1'
NOTE: Tasks Summary: Attempted 5006 tasks of which 4907 didn't need to be rerun and 1 failed.
No errror in the logfile above, but plenty of warnings complaining about the include path, which is apparently wrong:
But no idea, how could I adjust it.
FDomí1
Just in case, but did you make sure that you have node installed in your host system? If not install it:
sudo apt-get install nodejs
clean the recipes and try again. Besides that, I have no other suggestion. Good luck!
- Federico
IIstv
I have returned back to the method described in the Edison BSP document. It went quite well, except some checksum fixes. But then I got stuck with an error again:
ERROR: Function failed: Unpack failure for URL: 'http://downloads.sourceforge.net/sshpass/sshpass-1.05.tar.gz http://downloads.sourceforge.net/sshpass/sshpass-1.05.tar.gz'
Log:
Log data follows:
| DEBUG: Executing python function do_unpack
| DEBUG: Executing python function base_do_unpack
| NOTE: Unpacking /mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/poky/bbcache/downloads/sshpass-1.05.tar.gz to /mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/poky/out/linux64/build/tmp/work/core2-32-poky-linux/sshpass/1.05-r0.0/
| gzip: stdin: not in gzip format
| tar: Child returned status 1
| tar: Error is not recoverable: exiting now
| DEBUG: Python function base_do_unpack finished
| DEBUG: Python function do_unpack finished
Checked the downloaded sshpass-1.05.tar.gz and it is in fact a simple html message stating:
We're sorry -- the Sourceforge site is currently in Disaster Recovery mode, and currently requires
the use of javascript to function. Please check back later.
IIstv
6 hours later I downloaded the same file with wget, tested it, and this time I could unpack what I got.
After a bitbake -c clean sshpass it was running again...
...for another 10 minutes. Then:
ERROR: Function failed: do_compile (log file is located at /mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/poky/out/linux64/build/tmp/work/core2-32-poky-linux/xdk-daemon/0.0.35-r0/temp/log.do_compile.20428)
ERROR: Logfile of failure stored in: /mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/poky/out/linux64/build/tmp/work/core2-32-poky-linux/xdk-daemon/0.0.35-r0/temp/log.do_compile.20428
Log data follows:
| DEBUG: Executing shell function do_compile
| /mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/poky/out/linux64/build/tmp/work/core2-32-poky-linux/xdk-daemon/0.0.35-r0/temp/run.do_compile.20428: 125: [: i586: unexpected operator
| npm WARN package.json keepAlive@ No repository field.
| ncp@0.5.1 node_modules/ncp
| promise@5.0.0 node_modules/promise
| └── asap@1.0.0
| npm WARN package.json IoT_App_Daemon@ No repository field.
| npm WARN package.json IoT_App_Daemon@ No README data
| > ws@0.4.31 install /mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/poky/out/linux64/build/tmp/work/core2-32-poky-linux/xdk-daemon/0.0.35-r0/xdk-daemon-0.0.35/current/node_modules/ws
| > (node-gyp rebuild 2> builderror.log) || (exit 0)
| > mdns@2.2.8 install /mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/poky/out/linux64/build/tmp/work/core2-32-poky-linux/xdk-daemon/0.0.35-r0/xdk-daemon-0.0.35/current/node_modules/mdns
| > node-gyp rebuild
| Usage: gyp_main.py [options ...] [build_file ...]
| gyp_main.py: error: no such option: --no-parallel
| gyp ERR! configure error
| gyp ERR! stack Error: `gyp` failed with exit code: 2
| gyp ERR! stack at ChildProcess.onCpExit (/mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/poky/out/linux64/build/tmp/sysroots/x86_64-linux/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:343:16)
| gyp ERR! stack at ChildProcess.emit (events.js:98:17)
| gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:820:12)
| gyp ERR! System Linux 3.19.0-64-generic
| gyp ERR! command "node" "/mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/poky/out/linux64/build/tmp/sysroots/x86_64-linux/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
| gyp ERR! cwd /mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/poky/out/linux64/build/tmp/work/core2-32-poky-linux/xdk-daemon/0.0.35-r0/xdk-daemon-0.0.35/current/node_modules/mdns
| gyp ERR! node -v v0.10.38
| gyp ERR! node-gyp -v v1.0.1
| gyp ERR! not ok
| npm ERR! mdns@2.2.8 install: `node-gyp rebuild`
| npm ERR! Exit status 1
| npm ERR!
| npm ERR! Failed at the mdns@2.2.8 install script.
| npm ERR! This is most likely a problem with the mdns package,
| npm ERR! not with npm itself.
| npm ERR! Tell the author that this fails on your system:
| npm ERR! node-gyp rebuild
| npm ERR! You can get their info via:
| npm ERR! npm owner ls mdns
Investigation starts again.
Not really a flawless process....
I started a new search about gyp complaining about the --no-parallel option.
It seems like it was introduced in a later version of gyp, but Ubuntu 14.04 repo contains an older one, which cannot interpret this option.
I removed gyp with
sudo apt-get --purge remove gyp
and finally the build process went all the way.
Now comes the interesting part: configure the kernel, install nfs in it, rebuild and flash it.
Kernel configuration:
in poky/out/linux64/build I issued:
bitbake virtual/kernel -c menuconfig
File Systems ---> Network File Systems --->
<*> NFS server support │ │
│ │ -*- NFS server support for NFS version 3 │ │
│ │ [*] NFS server support for the NFSv3 ACL protocol extension│ │
│ │ [*] NFS server support for NFS version 4
Then Save and Exit.
The Path names in the BSP document don't match at all, so I did a search to find the .config with:
find tmp/ -mmin -5
which found the new .config here:
tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/linux-externalsrc-1.0/.config
Then the BSP document says:
" When the configuration is completed, replace defconfig with .config, then rename it back to defconfig. We also
suggest taking a backup of the defconfig file. Force bitbake to copy the modified defconfig file to the actual build
directory. Then the new image with modified kernel is ready to build."
This does not make too much sense for me. The path names in the document are totally different from the SDK path names, and when I searched for defconfig I found dozens of it.
Which is the valid one used by the kernel build process? After another couple of days spent with the build, it would be nice if someone could help me.
Community Manager
Hi if,
Thank you for the detailed description of the process you've followed so far. We'll definitively try to help you solve this issue. We'll run some tests, compare our results and then come back to you.
-Sergio
Community Manager
IIstv
Thank you. I am very sorry, but these links don't seem to have any use without being able to custom-build the Yocto edison image. Unfortunately with the image 20160606 following the process described in "Intel® Edison Board Support Package User Guide (May 2015 Document Number: 331188-006), I fail to do that.
is completed without errors:
Build Configuration:
BB_VERSION = "1.24.0"
BUILD_SYS = "x86_64-linux"
NATIVELSBSTRING = "Ubuntu-14.04"
TARGET_SYS = "i586-poky-linux"
MACHINE = "edison"
DISTRO = "poky-edison"
DISTRO_VERSION = "1.7.2"
TUNE_FEATURES = "m32 core2"
TARGET_FPU = ""
meta
meta-yocto
meta-yocto-bsp = "(detachedfromyocto-1.7.2):29812e61736a95f1de64b3e9ebbb9c646ebd28dd"
meta-intel-edison-bsp
meta-intel-edison-distro = ":"
meta-intel-iot-middleware = "(detachedfromc6d6814):c6d681475e76107e6c04c5f7a06034dc9e772d1e"
meta-intel-arduino = ":"
meta-arduino = "1.6.x:541b127163acb243109f07141bf249da2ecdcd9a"
NOTE: Preparing runqueue
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
NOTE: Tasks Summary: Attempted 3871 tasks of which 3868 didn't need to be rerun and all succeeded.
However I cannot find the generated image.
Running the command:
../meta-intel-edison/utils/flags/postBuild.sh
returns with error messages:
stat: cannot stat '/mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/poky/build/tmp/deploy/images/edison/edison-image-edison.ext4': No such file or directory
On page 7 the BSP document says: "When the bitbake process completes, images to flash are created in the edison-src/build/tmp/deploy/images/edison directory."
But tmp does not contain a deploy directory. What do I miss here?
(BTW this subject looks very much like off-tobic to me. Should I start another discussion with this problem?)
Community Manager
I noticed you used the command ../meta-intel-edison/utils/flags/postBuild.sh. The proper command should be /meta-intel-edison/utils/flash/postBuild.sh. Can you confirm this is not the cause of the error?
-Sergio
IIstv
I typed the command above, so it is a typo.
In sharp operation I used the correct one:
../meta-intel-edison/utils/flash/postBuild.sh
../meta-intel-edison/utils/flash/postBuild.sh: line 30: / 1048576: syntax error: operand expected (error token is "/ 1048576")
EDISON_ROOTFS_MB = 1536, IMAGE_SIZE_MB =
../meta-intel-edison/utils/flash/postBuild.sh: line 35: [: 1536: unary operator expected
cp: cannot stat '/mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/poky/build/tmp/deploy/images/edison/edison-image-edison.hddimg': No such file or directory
cp: cannot stat '/mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/poky/build/tmp/deploy/images/edison/u-boot-edison.img': No such file or directory
cp: cannot stat '/mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/poky/build/tmp/deploy/images/edison/u-boot-edison.bin': No such file or directory
cp: cannot stat '/mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/poky/build/tmp/deploy/images/edison/u-boot-envs': No such file or directory
1+0 records in
1+0 records out
4194304 bytes (4,2 MB) copied, 0,00652614 s, 643 MB/s
1+0 records in
1+0 records out
4194304 bytes (4,2 MB) copied, 0,00651613 s, 644 MB/s
1+0 records in
1+0 records out
4194304 bytes (4,2 MB) copied, 0,00534466 s, 785 MB/s
1+0 records in
1+0 records out
4194304 bytes (4,2 MB) copied, 0,00655226 s, 640 MB/s
1+0 records in
1+0 records out
4194304 bytes (4,2 MB) copied, 0,00425187 s, 986 MB/s
1+0 records in
1+0 records out
4194304 bytes (4,2 MB) copied, 0,00775396 s, 541 MB/s
1+0 records in
1+0 records out
4194304 bytes (4,2 MB) copied, 0,00415656 s, 1,0 GB/s
cp: cannot stat '/mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/poky/build/tmp/deploy/images/edison/edison-image-edison.ext4': No such file or directory
cp: cannot stat '/mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/poky/build/tmp/deploy/images/edison/vmlinux': No such file or directory
find: `/mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/poky/build/tmp/work/edison-poky-linux/u-boot': No such file or directory
Error : ota_update.scr creation failed, mkimage tool not found
Which is quite reasonable, because src/poky/build/tmp looks like this:
-rw-rw-r-- 1 istvan istvan 1 júl 14 17:22 abi_version
drwxrwxr-x 3 istvan istvan 4096 júl 14 17:22 cache
drwxrwxr-x 3 istvan istvan 4096 júl 14 17:22 log
-rw-rw-r-- 1 istvan istvan 96 júl 14 17:22 saved_tmpdir
No deploy directory.
IIstv
I managed to go all the way down with the kernel compilation, but NFS still does not work.
In the previous posts I was actually less than the inch from finishing the process, but in case others have difficulties with building the 20160606 image, here is the short summary of the process:
After having downloaded and untarred the package, the base directory of my explanation will be:
I'll refer to it as
I Entered /poky, and started the setup script. It would be possible to ammend some working directories (like download cache) but I let it use the default values.
./meta-intel-edison/setup.sh
After completion it will tell us how to proceed:
cd /mnt/edison/iot-devkit-yp-poky-edison-20160606/iot-devkit-yp-poky-edison-20160606/poky/out/linux64
source poky/oe-init-build-env
The first round of this bitbake takes a few hours, and it may stop with some errors, but I have fixed those (see previous posts.).
When the process was completed, it reported 3871 tasks.
Finally I found the generated image here:
/poky/out/linux64/build/tmp/deploy/images/edison/
I configured the kernel in:
with:
In file systems I found NFS3 server support marked. [*]
I also marked the NFS4 served support.
--- Network File Systems │ │
│ │ <*> NFS client support │ │
│ │ <*> NFS client support for NFS version 2 │ │
│ │ <*> NFS client support for NFS version 3 │ │
│ │ [*] NFS client support for the NFSv3 ACL protocol extension │ │
│ │ <*> NFS client support for NFS version 4 │ │
│ │ [ ] Provide swap over NFS support │ │
│ │ [ ] NFS client support for NFSv4.1 │ │
│ │ [ ] Use the legacy NFS DNS resolver │ │
│ │ <*> NFS server support │ │
│ │ [*] NFS server support for the NFSv3 ACL protocol extension │ │
│ │ [*] NFS server support for NFS version 4 │ │
│ │ [ ] NFS server manual fault injection (NEW) │ │
│ │ [ ] RPC: Enable dprintk debugging │ │
│ │ < > Ceph distributed file system │ │
│ │ < > CIFS support (advanced network filesystem, SMBFS successor) │ │
│ │ < > NCP file system support (to mount NetWare volumes) │ │
│ │ < > Coda file system support (advanced network fs) │ │
│ │ < > Andrew File System support (AFS)
Saved .config
With find ./ -mmin -5 I found the new .config here:
/poky/out/linux64/build/tmp/work/edison-poky-linux/linux-externalsrc/1.0-r2/linux-externalsrc-1.0/.config
I copied it into this file:
/poky/linux-kernel/arch/x86/configs/ i386_edison_defconfig
Then I cleaned the existing kernel target, to make bitbake rebuild it:
bitbake -c clean linux-externalsrc
I rebuilt the image with:
Copied it into the toFlash directory:
/poky$ meta-intel-edison/utils/flash/postBuild.sh out/linux64/build
Entered the toFlash directory:
cd ../../../out/linux64/build/toFlash/
Connected the USB cable to the mini breakout board usb connector (next to the power pins) and started flashall.sh
In a few minutes the flash process was completed fine.
After another two minutes (as proposed) I rebooted the unit, and checked nfs-utils with
opkg list | grep nfs
libnfsidmap-dbg - 0.25-r0 - NFS id mapping library - Debugging files NFS id mapping library. This
libnfsidmap-dev - 0.25-r0 - NFS id mapping library - Development files NFS id mapping library. This
libnfsidmap-doc - 0.25-r0 - NFS id mapping library - Documentation files NFS id mapping library.
libnfsidmap-staticdev - 0.25-r0 - NFS id mapping library - Development files (Static Libraries) NFS id
libnfsidmap0 - 0.25-r0 - NFS id mapping library NFS id mapping library.
nfs-utils - 1.3.0-r0 - userspace utilities for kernel nfs The nfs-utils package provides a
nfs-utils-client - 1.3.0-r0 - userspace utilities for kernel nfs The nfs-utils package provides a
nfs-utils-dbg - 1.3.0-r0 - userspace utilities for kernel nfs - Debugging files The nfs-utils
nfs-utils-dev - 1.3.0-r0 - userspace utilities for kernel nfs - Development files The nfs-utils
nfs-utils-doc - 1.3.0-r0 - userspace utilities for kernel nfs - Documentation files The nfs-utils
nfs-utils-stats - 1.3.0-r0 - userspace utilities for kernel nfs The nfs-utils package provides a
Which to me seems like installed properly.
I tested if nfs was available to rpcbind with
rpcinfo -p localhost
However all it says is:
Is there anything else I can do here?
Community Manager
We'll investigate and post a reply shortly. Thank you for your patience.
-Sergio
