I want to get some libraries for node, but my terminal says npm is not a command
please help. i am trying to work on another project and need NPM.
thks.
Hi JimmyIsTheBoss,
Take a look at
BR,
Fernando.
I keep getting iotdk.intel.com bad address
after running opkg update
i also get wget returned 1
Hello JimmyIsTheBoss,
Thanks for reaching out!
Could you please let us know the image you are using? You can verify this information with the command:
cat /etc/version
You should see the output 201605251601. In case you are receiving a different output, you will have to update to the latest image, which can downloaded from https://software.intel.com/en-us/iot/hardware/galileo/downloads. I suggest you to follow this guide: https://software.intel.com/en-us/get-started-galileo-windows-step1 in order to learn how to do it.
Once you are on the latest image, set an internet connection on your Galileo by either using an Ethernet cable or by setting wireless connectivity (learn how to do it in https://software.intel.com/en-us/get-started-galileo-windows-step4 or in http://www.malinov.com/Home/sergey-s-blog/intelgalileo-addingwifi) and then enter the following commands:
opkg update
opkg install nodejs-npm
When the commands finish running, you should be able to use npm.
Let me know how it goes.
-Peter.
i figured it out
first i added "src npm http://iotdk.intel.com/repos/3.5/iotdk/galileo/i586/" to /etc/opkg/iotdk.conf
then i ran opkg update
last i ran opkg install nodejs-npm
thanks
JimmyIsTheBoss wrote:
i figured it out
first i added "src npm http://iotdk.intel.com/repos/3.5/iotdk/galileo/i586/ http://iotdk.intel.com/repos/3.5/iotdk/galileo/i586/" to /etc/opkg/iotdk.conf
thanks
That's documented in the link I posted above,
Fernando.
