Community
cancel
Showing results for
Search instead for
Did you mean:
FNich
Need ONLY latest kernel & modules (I run Gentoo Linux on my Edisons)
I'm looking for the latest pre-compiled kernel & modules for the Intel Edison. I run Gentoo Linux, and am using the following kernel:
Linux edisons 3.10.17-yocto-standard-r2 # 7 SMP PREEMPT Thu Feb 26 09:57:06 UTC 2015 i686 Genuine Intel(R) CPU 4000 @ 500MHz GenuineIntel GNU/Linux
I am experienced in building kernels (I run Gentoo, after all... ). If a precompiled kernel is not available, please point me to just the kernel source and build options.
Thanks in advance for pointing me to the kernel, or the source & build options.
Frank
Community Manager
I believe you'll find what you're looking for here https://software.intel.com/en-us/iot/hardware/edison/downloads https://software.intel.com/en-us/iot/hardware/edison/downloads under the "Intel® Edison Board Firmware Software Release 3.0" section.
Sergio
FNich
Unless I'm missing it, what I am looking for is not there. I do not want a complete image to flash to my Edison's - my Edison's already have Gentoo linux running on it them. I want JUST the kernel & modules, or the kernel source & configuration file so I can compile my own. I did not see either of these at the download link, or any easy way to get them from what is linked...
If I did miss it, please provide the link to the proper download.
Frank
FNich
BTW - I thought this might be it, "http://iotdk.intel.com/repos/3.0/sources/i586-poky-linux/edison-image-1.0-r0/edison-image-1.0-r0-pat... Sources – Linux Source Files", but that was an empty tar ball...
Community Manager
The Linux source files should be on the link you posted. We've reported this situation to the proper team and are working on getting this fixed. I'll post a reply here once everything is working properly.
Sergio
