Intel® Makers
9868 Discussions
Need help correctly building MRAA and dependencies
RTang4
I am having trouble building MRAA and the dependencies on my Edison. I am new to this and am going off of the instructions located here: http://iotdk.intel.com/docs/master/mraa/java/building.html http://iotdk.intel.com/docs/master/mraa/java/building.html
If anyone can help me with step by step instructions it would be greatly appreciated. I am using a debian distro.
Thank you!
RTang4
I just used the tutorial found on sparkfun: https://learn.sparkfun.com/tutorials/installing-libmraa-on-ubilinux-for-edison Installing libmraa on Ubilinux for Edison - learn.sparkfun.com and received an error when I ran this part of the code:
git clone https://github.com/intel-iot-devkit/mraa.git
mkdir mraa/build && cd $_
cmake .. -DBUILDSWIGNODE=OFF
make
make install
cd
The error received is:
-- INFO - libmraa Version v1.1.1-5-g1af737f
-- INFO - cmake Version 2.8.9
-- INFO - Target arch is i586
-- Could NOT find PythonInterp: Found unsuitable version "2.7.3", but required is at least "3" (found /usr/bin/python)
-- Could NOT find PythonInterp: Found unsuitable version "2.7.3", but required is at least "3.2" (found /usr/bin/python)
-- INFO - Adding onewire backend support
-- INFO - Adding support for platform ALL
-- INFO - Adding support for all platforms
INFO - Adding x86 platforms
PYTHON2 attempting to build!
CMake Error at src/python/python2/CMakeLists.txt:10 (target_include_directories):
Unknown CMake command "target_include_directories".
Community Manager
Hello ProgrammingN00b,
If you were using the official image for Edison (based on Yocto), installing mraa would be a very simple task. You would only need to set the official repo and download package from it.
Since you are on Ubilinux, I would suggest you to verify that all of the dependencies are correctly installed and if they are, I'd suggest you to follow the instructions in http://iotdk.intel.com/docs/master/mraa/java/building.html and file an issue with the full output of cmake or however far you got.
If that was the case, you can submit an issue in https://github.com/intel-iot-devkit/mraa/issues.
-Peter.
