Intel® Makers
9882 Discussions
Need help for building uwsgi with PCRE support
GBaim
I'm trying to use nginx+flask+uwsgi for my smart home telegram bot, but unfortunately, I can't get correct install for uwsgi. Everything is fine, except one thing - uwsgi doesn't recognize pcre libs
I have all pcre libs installed:
opkg install libpcre-dev libpcre1 libpcre-staticdev
But during pip install uwsgi, I get such screen:
# uWSGI configuration #
pcre = False
I even tried to update pip and compile pcre libs, but it didn't help. After start I get such errors:
!!! no internal routing support, rebuild with pcre support !!!
GBaim
I've found my mistake - I tried to build pcre2, but uwsgi needed plain one. After building latest pcre with following options, uwsgi recognized it:
./configure --enable-utf --enable-unicode-properties --enable-jit
GBaim
