Intel® Makers
Intel® Edison, Intel® Joule™, Intel® Curie™, Intel® Galileo
Welcome - This is a Peer-to-Peer Forum only. Intel has discontinued these products but you may find support from other customers on this Forum
9868 Discussions
Need help reading SerialPort for javaScript
KSels
New Contributor II
I got my starter code for Serial write to work, but now I want to read SerialPort.
How do I read several strings at the same time? like the GPS sends.
Demo code from the GPS.
$GPGGA,123519,4807.038,N,01131.000,E,1,08,0.9,545.4,M,46.9,M,,*47
$GPGSA,A,3,04,05,,09,12,,,24,,,,,2.5,1.3,2.1*39
$GPGSV,2,1,08,01,40,083,46,02,17,308,41,12,07,344,39,14,22,228,45*75
$GPRMC,123519,A,4807.038,N,01131.000,E,022.4,084.4,230394,003.1,W*6A
$GPGLL,4916.45,N,12311.12,W,225444,A,*1D
$GPVTG,054.7,T,034.4,M,005.5,N,010.2,K*48
I want to get the GGA and RMC. How do I read these data only from the list at top?
Here is my GGA code (under), but I cant get the GGA and RMC data to work at the same time.
serialPort.on('data', function(data) {
var data_string = '' + data;
console.log(data_string);
ws.write(data_string);
if (data_string.substring(0,6) == '$GPGGA') {
gpgga_string = data_string.split('\n')[0];
gpgga_string = gpgga_string.replace('\n', '');
gps_data = gpgga_string.split(',');
console.log('data received: ' + gps_data);
var time_string = gps_data[1];
var gps_time = new Date();
var gps_time_hours = parseInt(gps_data[1].substring(0,2));
var gps_time_minutes = parseInt(gps_data[1].substring(2,4));
var gps_time_seconds = parseInt(gps_data[1].substring(4,6));
gps_time.setHours(gps_time_hours);
gps_time.setMinutes(gps_time_minutes);
gps_time.setSeconds(gps_time_seconds);
gps_lat = gps_data[2];
gps_lat_ns = gps_data[3];
gps_lon = gps_data[4];
gps_lon_ew = gps_data[5];
gps_pos_fix = gps_data[6];
gps_satt_qty = gps_data[7];
gps_hdop = gps_data[8];
gps_msl_alt = gps_data[9];
gps_unit = gps_data[10];
gps_geo = gps_data[11];
gps_geo_unit = gps_data[12];
if (gps_pos_fix == '1') {
console.log('GPS Fixed');
console.log('Time: ', gps_time);
console.log('Position: ' + gps_lat + gps_lat_ns + ',' + gps_lon + gps_lon_ew);
console.log('Altitude: ' + gps_msl_alt + 'M' + ' +/- ' + gps_hdop + 'M');
console.log('Satellites Qty: ' + gps_satt_qty + '\n');
if (gps_pos_fix == '2') {
console.log('DGPS Fixed');
if (gps_pos_fix == '0') {
console.log('No GPS Fix');
Carlos_M_Intel
Hi Kim,
If you are going to use Serial Communication you can't read more than one value at a time, this is because there is only one RX line available so the system will be receiving the information continuously and not in parallel.
You will need to create a routine that will read first GCA and then RMC.
Charlie
KSels
New Contributor II
Looks like I got it working. It gives me the data I need right now. But time will tell when the javaScript gets bigger.
var com = require("serialport");
var serialPort = new com.SerialPort("/dev/ttyMFD1", {
baudrate: 9600,
parser: com.parsers.readline('\r\n')
// receive GPS (data)
var PMTK_SET_NMEA_UPDATE_1HZ = "$PMTK220,1000*1F";
var PMTK_SET_NMEA_UPDATE_5HZ = "$PMTK220,200*2C";
var PMTK_SET_NMEA_UPDATE_10HZ = "$PMTK220,100*2F";
// Baud Rate 0(default = 9600) - 115200
var PMTK_SET_NMEA_BAUDRATE_0 = "$PMTK251,0*28";
var PMTK_SET_NMEA_BAUDRATE_4800 = "$PMTK251,4800*14";
var PMTK_SET_NMEA_BAUDRATE_9600 = "$PMTK251,9600*17";
var PMTK_SET_NMEA_BAUDRATE_14400 = "$PMTK251,14400*29";
var PMTK_SET_NMEA_BAUDRATE_19200 = "$PMTK251,19200*22";
var PMTK_SET_NMEA_BAUDRATE_38400 = "$PMTK251,38400*27";
var PMTK_SET_NMEA_BAUDRATE_57600 = "$PMTK251,57600*2C";
var PMTK_SET_NMEA_BAUDRATE_115200 = "$PMTK251,115200*1F";
// turn on only the second sentence (GPRMC)
var PMTK_SET_NMEA_OUTPUT_RMC = "$PMTK314,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29";
// GGA only
var PMTK_SET_NMEA_OUTPUT_GGA = "$PMTK314,0,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29";
// turn on RMC and GGA
var PMTK_SET_NMEA_OUTPUT_RMCGGA = "$PMTK314,0,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28";
// turn on RMC, GGA and GSA
var PMTK_SET_NMEA_OUTPUT_RMCGGAGSA = "$PMTK314,0,1,0,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29";
// turn on ALL THE DATA
var PMTK_SET_NMEA_OUTPUT_ALLDATA = "$PMTK314,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0*28";
// turn off output
var PMTK_SET_NMEA_OUTPUT_OFF = "$PMTK314,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28";
// Standby
var PMTK_STANDBY = "$PMTK161,0*28";
var PMTK_Q_RELEASE = "$PMTK605*31";
// Ant off
var PMTK_ANT_OFF = "$PGCMD,33,0*6D";
// Active Interference Cancellation (AIC) Disable
var PMTK_AIC_OFF = "$PMTK286,0*22";
// Active Interference Cancellation (AIC) Enable
var PMTK_AIC_ON = "$PMTK286,1*23";
// DGPS Mode
var PMTK_DT_DGPS_MODE = "$PMTK401*37";
function delay(milliseconds)
var startTime = Date.now();
while (Date.now() - startTime < milliseconds);
serialPort.on('open',function() {
console.log('Port open');
serialPort.write(PMTK_SET_NMEA_OUTPUT_RMCGGA + "\r\n"); // RMC and GGA
console.log(PMTK_SET_NMEA_OUTPUT_RMCGGA);
delay(200);
serialPort.write(PMTK_DT_DGPS_MODE + "\r\n"); // DGPS
console.log(PMTK_DT_DGPS_MODE);
delay(200);
serialPort.write(PMTK_SET_NMEA_UPDATE_1HZ + "\r\n"); // 5Hz
console.log(PMTK_SET_NMEA_UPDATE_5HZ);
delay(200);
serialPort.write(PMTK_AIC_ON + "\r\n"); // AIC ON
console.log(PMTK_AIC_ON);
delay(200);
//console.log(data);
//console.log('GGA found');
console.log('GGA data received: ' + gps_data);
console.log('GGA GPS Fixed');
console.log('Time: ', gps_time_hours + ':' + gps_time_minutes + ':' + gps_time_seconds);
if (data_string.substring(0,6) == '$GPRMC') {
//console.log('RMC found');
gprmc_string = data_string.split('\n')[0];
gprmc_string = gprmc_string.replace('\n', '');
gps_data = gprmc_string.split(',');
console.log('RMC data received: ' + gps_data);
gps_pos_fix = gps_data[2];
gps_lat = gps_data[3];
gps_lat_ns = gps_data[4];
gps_lon = gps_data[5];
gps_lon_ew = gps_data[6];
gps_speed = gps_data[7];
gps_track_...
KSels
New Contributor II
I added GSA and SD card logging also to my GPS script. Still looking good.
var m = require('mraa'); //require mraa
var fs = require('fs'); // require filesystem
baudrate: 9600,
// Create .txt file
var ws = fs.createWriteStream('/media/sdcard/GPS.txt');
// GGA only
// turn off output
// Standby
// Ant off
// DGPS Mode
// Starting logging data to SD
var GPS_log = false;
serialPort.write(PMTK_SET_NMEA_OUTPUT_RMCGGAGSA + "\r\n"); // RMC, GGA and GSA
console.log(PMTK_SET_NMEA_OUTPUT_RMCGGAGSA);
delay(500);
delay(500);
serialPort.write(PMTK_SET_NMEA_UPDATE_1HZ + "\r\n"); // 1Hz
delay(500);
delay(500);
GPS_log = true;
var time_string = gps_data[1]; // Fix Time HH:MM:SS
gps_lat = gps_data[2]; // Latitude
gps_lat_ns = gps_data[3]; // Latitude
gps_lon = gps_data[4]; // Longitude
gps_lon_ew = gps_data[5]; // Longitude
gps_pos_fix = gps_data[6]; // Fix Quality 1-8
gps_satt_qty = gps_data[7]; // Number of satellites
gps_hdop = gps_data[8]; // Horizontal dilution of position
gps_msl_alt = gps_data[9]; // Altitude above sea level
gps_unit = gps_data[10]; // Meters
gps_geo = gps_data[11]; // Height of geoid above WGS84
gps_geo_unit = gps_data[12]; // Meters
gps_dgps = gps_data[13]; // DGPS laste update time
gps_dgps_id = gps_data[14]; // DGPS station ID number
ws.write(data_string + '\n');
console.log('Altitude: ' + gps_msl_alt + 'M' + ' +/- ' + g...
