I got my starter code for Serial write to work, but now I want to read SerialPort.
How do I read several strings at the same time? like the GPS sends.
Demo code from the GPS.
$GPGGA,123519,4807.038,N,01131.000,E,1,08,0.9,545.4,M,46.9,M,,*47
$GPGSA,A,3,04,05,,09,12,,,24,,,,,2.5,1.3,2.1*39
$GPGSV,2,1,08,01,40,083,46,02,17,308,41,12,07,344,39,14,22,228,45*75
$GPRMC,123519,A,4807.038,N,01131.000,E,022.4,084.4,230394,003.1,W*6A
$GPGLL,4916.45,N,12311.12,W,225444,A,*1D
$GPVTG,054.7,T,034.4,M,005.5,N,010.2,K*48
I want to get the GGA and RMC. How do I read these data only from the list at top?
Here is my GGA code (under), but I cant get the GGA and RMC data to work at the same time.
serialPort.on('data', function(data) {
var data_string = '' + data;
console.log(data_string);
ws.write(data_string);
if (data_string.substring(0,6) == '$GPGGA') {
gpgga_string = data_string.split('\n')[0];
gpgga_string = gpgga_string.replace('\n', '');
gps_data = gpgga_string.split(',');
console.log('data received: ' + gps_data);
var time_string = gps_data[1];
var gps_time = new Date();
var gps_time_hours = parseInt(gps_data[1].substring(0,2));
var gps_time_minutes = parseInt(gps_data[1].substring(2,4));
var gps_time_seconds = parseInt(gps_data[1].substring(4,6));
gps_time.setHours(gps_time_hours);
gps_time.setMinutes(gps_time_minutes);
gps_time.setSeconds(gps_time_seconds);
gps_lat = gps_data[2];
gps_lat_ns = gps_data[3];
gps_lon = gps_data[4];
gps_lon_ew = gps_data[5];
gps_pos_fix = gps_data[6];
gps_satt_qty = gps_data[7];
gps_hdop = gps_data[8];
gps_msl_alt = gps_data[9];
gps_unit = gps_data[10];
gps_geo = gps_data[11];
gps_geo_unit = gps_data[12];
if (gps_pos_fix == '1') {
console.log('GPS Fixed');
console.log('Time: ', gps_time);
console.log('Position: ' + gps_lat + gps_lat_ns + ',' + gps_lon + gps_lon_ew);
console.log('Altitude: ' + gps_msl_alt + 'M' + ' +/- ' + gps_hdop + 'M');
console.log('Satellites Qty: ' + gps_satt_qty + '\n');
if (gps_pos_fix == '2') {
console.log('DGPS Fixed');
if (gps_pos_fix == '0') {
console.log('No GPS Fix');
Hi Kim,
If you are going to use Serial Communication you can't read more than one value at a time, this is because there is only one RX line available so the system will be receiving the information continuously and not in parallel.
You will need to create a routine that will read first GCA and then RMC.
Charlie
Looks like I got it working. It gives me the data I need right now. But time will tell when the javaScript gets bigger.
var com = require("serialport");
var serialPort = new com.SerialPort("/dev/ttyMFD1", {
baudrate: 9600,
parser: com.parsers.readline('\r\n')
// receive GPS (data)
var PMTK_SET_NMEA_UPDATE_1HZ = "$PMTK220,1000*1F";
var PMTK_SET_NMEA_UPDATE_5HZ = "$PMTK220,200*2C";
var PMTK_SET_NMEA_UPDATE_10HZ = "$PMTK220,100*2F";
// Baud Rate 0(default = 9600) - 115200
var PMTK_SET_NMEA_BAUDRATE_0 = "$PMTK251,0*28";
var PMTK_SET_NMEA_BAUDRATE_4800 = "$PMTK251,4800*14";
var PMTK_SET_NMEA_BAUDRATE_9600 = "$PMTK251,9600*17";
var PMTK_SET_NMEA_BAUDRATE_14400 = "$PMTK251,14400*29";
var PMTK_SET_NMEA_BAUDRATE_19200 = "$PMTK251,19200*22";
var PMTK_SET_NMEA_BAUDRATE_38400 = "$PMTK251,38400*27";
var PMTK_SET_NMEA_BAUDRATE_57600 = "$PMTK251,57600*2C";
var PMTK_SET_NMEA_BAUDRATE_115200 = "$PMTK251,115200*1F";
// turn on only the second sentence (GPRMC)
var PMTK_SET_NMEA_OUTPUT_RMC = "$PMTK314,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29";
// GGA only
var PMTK_SET_NMEA_OUTPUT_GGA = "$PMTK314,0,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29";
// turn on RMC and GGA
var PMTK_SET_NMEA_OUTPUT_RMCGGA = "$PMTK314,0,1,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28";
// turn on RMC, GGA and GSA
var PMTK_SET_NMEA_OUTPUT_RMCGGAGSA = "$PMTK314,0,1,0,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0*29";
// turn on ALL THE DATA
var PMTK_SET_NMEA_OUTPUT_ALLDATA = "$PMTK314,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0,0,0*28";
// turn off output
var PMTK_SET_NMEA_OUTPUT_OFF = "$PMTK314,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0*28";
// Standby
var PMTK_STANDBY = "$PMTK161,0*28";
var PMTK_Q_RELEASE = "$PMTK605*31";
// Ant off
var PMTK_ANT_OFF = "$PGCMD,33,0*6D";
// Active Interference Cancellation (AIC) Disable
var PMTK_AIC_OFF = "$PMTK286,0*22";
// Active Interference Cancellation (AIC) Enable
var PMTK_AIC_ON = "$PMTK286,1*23";
// DGPS Mode
var PMTK_DT_DGPS_MODE = "$PMTK401*37";
function delay(milliseconds)
var startTime = Date.now();
while (Date.now() - startTime < milliseconds);
serialPort.on('open',function() {
console.log('Port open');
serialPort.write(PMTK_SET_NMEA_OUTPUT_RMCGGA + "\r\n"); // RMC and GGA
console.log(PMTK_SET_NMEA_OUTPUT_RMCGGA);
delay(200);
serialPort.write(PMTK_DT_DGPS_MODE + "\r\n"); // DGPS
console.log(PMTK_DT_DGPS_MODE);
delay(200);
serialPort.write(PMTK_SET_NMEA_UPDATE_1HZ + "\r\n"); // 5Hz
console.log(PMTK_SET_NMEA_UPDATE_5HZ);
delay(200);
serialPort.write(PMTK_AIC_ON + "\r\n"); // AIC ON
console.log(PMTK_AIC_ON);
delay(200);
//console.log(data);
//console.log('GGA found');
console.log('GGA data received: ' + gps_data);
console.log('GGA GPS Fixed');
console.log('Time: ', gps_time_hours + ':' + gps_time_minutes + ':' + gps_time_seconds);
if (data_string.substring(0,6) == '$GPRMC') {
//console.log('RMC found');
gprmc_string = data_string.split('\n')[0];
gprmc_string = gprmc_string.replace('\n', '');
gps_data = gprmc_string.split(',');
console.log('RMC data received: ' + gps_data);
gps_pos_fix = gps_data[2];
gps_lat = gps_data[3];
gps_lat_ns = gps_data[4];
gps_lon = gps_data[5];
gps_lon_ew = gps_data[6];
gps_speed = gps_data[7];
gps_track_...
I added GSA and SD card logging also to my GPS script. Still looking good.
var m = require('mraa'); //require mraa
var fs = require('fs'); // require filesystem
baudrate: 9600,
// Create .txt file
var ws = fs.createWriteStream('/media/sdcard/GPS.txt');
// GGA only
// turn off output
// Standby
// Ant off
// DGPS Mode
// Starting logging data to SD
var GPS_log = false;
serialPort.write(PMTK_SET_NMEA_OUTPUT_RMCGGAGSA + "\r\n"); // RMC, GGA and GSA
console.log(PMTK_SET_NMEA_OUTPUT_RMCGGAGSA);
delay(500);
delay(500);
serialPort.write(PMTK_SET_NMEA_UPDATE_1HZ + "\r\n"); // 1Hz
delay(500);
delay(500);
GPS_log = true;
var time_string = gps_data[1]; // Fix Time HH:MM:SS
gps_lat = gps_data[2]; // Latitude
gps_lat_ns = gps_data[3]; // Latitude
gps_lon = gps_data[4]; // Longitude
gps_lon_ew = gps_data[5]; // Longitude
gps_pos_fix = gps_data[6]; // Fix Quality 1-8
gps_satt_qty = gps_data[7]; // Number of satellites
gps_hdop = gps_data[8]; // Horizontal dilution of position
gps_msl_alt = gps_data[9]; // Altitude above sea level
gps_unit = gps_data[10]; // Meters
gps_geo = gps_data[11]; // Height of geoid above WGS84
gps_geo_unit = gps_data[12]; // Meters
gps_dgps = gps_data[13]; // DGPS laste update time
gps_dgps_id = gps_data[14]; // DGPS station ID number
ws.write(data_string + '\n');
console.log('Altitude: ' + gps_msl_alt + 'M' + ' +/- ' + g...
