Intel® Makers
9881 Discussions
Need to change enp0s20f6 to eth0 interface name in Intel galileo gen board
Community Manager
I am working on Yocto Linux Build System and also taken some reference of meta-clanton 1.1.0 for our custom board development which is based on Intel Quark x1000 SoC.
I have enabled systemd and connman services and seen that name of Ethernet interface is like "enp0s20f6" instead of standard eth0 and same for wireless interface network name. I have searched configuration file in connman but not found much details to change that interface from build system.
Does anyone has any idea or solution to change that interface name from Yocto Build System or Do I need to disable systemd service to get standard interface name?
Please let me know if anyone knows about that issue.
Note:- I have tried one test like I have disabled systemd service from my yocto configuration and got network configuration name like eth0 for Ethernet and wlan0 for WiFi Interface. So, it seems like name of both interface is changed after adding support of systemd services.
Ritesh Prajapati
Community Manager
In the eglibc image I was able to change the network interface name with these commands
ifconfig enp0s20f6 down  ip link set enp0s20f6 name eth0 ifconfig eth0 up
Let us know if this works for you.
-Sergio
FTinetti
Honored Contributor I
Works.
Now it is not necessary to have specific "names" for different libc based libraries. I'll post an update on this in thread
specifically about a webserver as a specific case.
Thank you,
Fernando.
Community Manager
Thanks for providing steps to change network interface name and it worked..
But, it worked only at that time means if i restart board after changing interface name to eth0 then interface name is changed to previous original one which is enp0s20f6. So, I want to change that interface name from enp0s20f6 to eth0 permanently from Yocto Build configuration or bb files.
I can do it from my custom systemd services at board boot-time as well but that solution is not proper as i need to down network to change that interface name on every restart.
Please provide any appropriate or permanent solution to change that interface from image itself if you or anyone else has any solution for that.
Ritesh Prajapati
Community Manager
I got one permanent solution to keep Ethernet Interface name as eth0 and Wireless Interface name as wlan0 which i found from another running thread.
ln -s /dev/null /etc/udev/rules.d/80-net-setup-link.rules
so, Anyone can configure above rule into custom Galileo build system to keep Ethernet and WiFi interfaces name as it it.
Ritesh Prajapati
Community Manager
Thank you for providing this solution. It'll definitively help other users in the community with similar issues.
-Sergio
