Community
cancel
Showing results for
Search instead for
Did you mean:
AShak3
Need to read data from DHT11 sensor
Can you tell me what can I use to read data from DHT11 sensor by using intel edison along with NodeJs? This is using 1-wire protocol. Npm package : node-dht edison only supports DHT22. Can you give me some hints to work on? I got this http://www.i-programmer.info/programming/hardware/9200-exploring-edison-bit-banging-the-dht11dht22-.... link to study. But facing a lot of problems in implementation.
I have attached the picture of DHT11 sensor that I am using.
Community Manager
Hello shakir1443,
Thanks for reaching out!
What are the issues that you have faced when trying to implement this code?
According to https://akizukidenshi.com/download/ds/aosong/DHT11.pdf the DHT11 communicates through a serial port, therefore it should be compatible with Edison. Unfortunately, I don't have access to one of this sensors but according to the document I shared above, it shouldn't be that hard to work with this sensor.
I'd suggest you to take a look at the DHT11 Product Manual that I shared above and to check mraa's Node.JS UART example ( https://github.com/intel-iot-devkit/mraa/blob/master/examples/javascript/uart.js) in order to get you started.
I hope this information helps you,
Pedro M.
Community Manager
Hello shakir1443,
Do you have any updates about this?
Pedro M.
