Community
cancel
Showing results for
Search instead for
Did you mean:
tmenk
New Edison board keeps "losing" Arduino sketches after reboot/reconnect
Jump to solution
Hello everyone,
I got my new Edison board yesterday and finished setting it up. I updated Linux, installed all the drivers and software, created a password and connected to WiFi from both serial and Arduino sketch.
I even got around to testing some shields on it and it worked perfectly.
I have this one annoying problem though, my Edison keeps forgetting the Arduino code uploaded to it no matter what. I tired shutting it down via serial, disconnecting the cables and even the power button and nothing seems to make my Arduino sketch stick.
Do i really need to re-upload them every time i boot the Edison?
Diego_V_Intel
Hi menkesi,
That's a known issue with the latest image version. I recommend you to re-flash the Edison with the following image version since this issue doesn't happen on it: https://downloadcenter.intel.com/downloads/eula/24910/Intel-Edison-Software-Release-2-1?httpDown=htt... Intel Edison Software Release 2.1
Diego
Diego_V_Intel
Hi menkesi,
Diego
tmenk
Thanks for the help, after trying to flash it with Phone Flash Tool Lite i only get errors.
How would you recommend to flash the Edison?
Diego_V_Intel
Hi menkesi,
I recommend you to use an alternative method that uses a script called flashall. This method is described in the following document:
Diego
