Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor I
New Edison layers based on Yocto Sumo and Linux 4.16
You can find the latest unofficial layer here: https://github.com/edison-fw/meta-intel-edison GitHub - edison-fw/meta-intel-edison: Here is the meta-intel-edison that builds, tries to stay up to date and provides a…
I case this doesn't ring any bells for you: the Yocto layer does not provide binary images, instead it is an automated tool to generate a binary image. You can also make changes to the tools installed on the edison or the kernel modules built.
We are moving and restructuring the documentation to this new repo, until that is done you can find documentation here https://htot.github.io/meta-intel-edison/ Intel Edison Image Builder |
I monitor the Telegram group Intel Edison to provide help as well.
