Hi, I hope someone can help me solving an issue with the HDMI audio on my STCK1A8LFC. It was probably unwise, but I updated (not upgraded) the Ubuntu 14.04 OS after a long time of not updating. After all the updates the system boots fine, but the HDMI audio does not work. It worked before the updates.
After booting Ubuntu 14.04, a window appears requesting for authentication to run '/usr/bin/env' as the super user. The "Action" is "org.freedesktop.policykit.exec", with "Vendor" being "The PolicyKit Project". After authentication, the "OEM LTS Installer" gives a warning: "Current LTS enablement stack will not be supported anymore so it needs to upgrade to the latest LTS enablement stack." Then the "OEM LTS Installer" updates Debian packages, upgrades LTS enablement stack, and reports:
Failed!
Check /var/log/oem-lts-stacks-installer.log for details.
So, I checked this log (attached) and these are the crucial lines:
Package 'oem-audio-i915-baytrail-dkms' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up oem-hdmi-audio-dkms (0.1) ...
Removing old oem-hdmi-audio-0.1 DKMS files...
Deleting module version: 0.1
completely from the DKMS tree.
Done.
Loading new oem-hdmi-audio-0.1 DKMS files...
First Installation: checking all kernels...
Building only for 4.4.0-104-generic
Building for architecture x86_64
Building initial module for 4.4.0-104-generic
Error! Bad return status for module build on kernel: 4.4.0-104-generic (x86_64)
Consult /var/lib/dkms/oem-hdmi-audio/0.1/build/make.log for more information.
dpkg: error processing package oem-hdmi-audio-dkms (--configure):
subprocess installed post-installation script returned error exit status 1
Processing triggers for initramfs-tools (0.103ubuntu4.9) ...
update-initramfs: Generating /boot/initrd.img-4.4.0-104-generic
Errors were encountered while processing:
oem-hdmi-audio-dkms
So, I consulted this "make.log" (attached), and find:
/var/lib/dkms/oem-hdmi-audio/0.1/build/intel_audio.c: In function 'intel_audio_codec_enable':
/var/lib/dkms/oem-hdmi-audio/0.1/build/intel_audio.c:533:3: error: too few arguments to function 'acomp->audio_ops->pin_eld_notify'
acomp->audio_ops->pin_eld_notify(acomp->audio_ops->audio_ptr, (int) port);
/var/lib/dkms/oem-hdmi-audio/0.1/build/intel_audio.c: In function 'intel_audio_codec_disable':
/var/lib/dkms/oem-hdmi-audio/0.1/build/intel_audio.c:560:3: error: too few arguments to function 'acomp->audio_ops->pin_eld_notify'
/var/lib/dkms/oem-hdmi-audio/0.1/build/intel_audio.c: At top level:
/var/lib/dkms/oem-hdmi-audio/0.1/build/intel_audio.c:756:2: warning: initialization from incompatible pointer type [enabled by default]
.sync_audio_rate = i915_audio_component_sync_audio_rate,
/var/lib/dkms/oem-hdmi-audio/0.1/build/intel_audio.c:756:2: warning: (near initialization for 'i915_audio_component_ops.sync_audio_rate') [enabled by default]
/var/lib/dkms/oem-hdmi-audio/0.1/build/intel_audio.c:757:2: warning: initialization from incompatible pointer type [enabled by default]
.get_eld = i915_audio_component_get_eld,
/var/lib/dkms/oem-hdmi-audio/0.1/build/intel_audio.c:757:2: warning: (near initialization for 'i915_audio_component_ops.get_eld') [enabled by default]
make[2]: *** [/var/lib/dkms/oem-hdmi-audio/0.1/build/intel_audio.o] Error 1
make[1]: *** [_module_/var/lib/dkms/oem-hdmi-audio/0.1/build] Error 2
make[1]: Leaving directory `/usr/src/linux-headers-4.4.0-104-generic'
make: *** [all] Error 2
How to solve this?
If you were using the original Ubuntu 14.04 that came on the STCK1A8LFC then the kernel was v3.16 and HDMI audio was provided by a DKMS package. When you 'updated' it actually 'upgraded' the LTS enablement stack from v3.16 to v4.4 as v3.16 was EOL. However as the DKMS package had a dependency on v3.16 failed when trying to build with the new v4.4 kernel. You can fix all this but it will be simpler to perform a fresh install having first saved any user files.
First in terms of OS flavour, personally I don't recommend Ubuntu on the STCK1A8LFC as it is too resource hungry for the device's specification. You will find that Lubuntu works much better.
Second in terms of OS release for HDMI audio to work you will want a release that supports the v4.11 kernel as a minimum as this contains the audio patches but because you have a STCK1A8LFC then you need the v4.12 kernel as a minimum as it contains the RTL8723BS wifi module. So you are looking at Ubuntu 16.04 running the upcoming HWE Stack (hwe-edge).
Third in terms of OS security following the public release of the Meltdown and Spectre vulnerabilities you need a kernel that includes fixes for Meltdown as a minimum. Unfortunately Canonical hasn't released their fixed kernels yet so you can either install the latest hwe-edge kernel for 16.04 or wait (likely only another 24 hours) for the updated and fixed kernel which, just to add to the confusion, will be the hwe kernel as the v4.10 hwe is being made EOL early so hwe will go to v4.13 early as a consequence.
Fourth in terms of OS booting and functionality you will need to ensure the BIOS setting for a 64-bit bootloader is selected (for OS select Ubuntu 14.04) if you install an official Ubuntu or Ubunto flavoured ISO and then you will need to add the Bluetooth userspace files for Bluetooth to function correctly.
I have written a script called 'isorespin.sh' that simplifies some of the above steps by respinning an official ISO and allows it to be updated. For example you can upgrade the kernel and include the necessary Bluetooth files prior to creating a LiveUSB from the respun ISO. For example I'd download and respin the Lubuntu 16.04.3 ISO using the invocation of '-i lubuntu-16.04.3-desktop-amd64.iso --atom --rolling-release-hwe -s 200MB' for the STCK1A8LFC. Having written the newly created ISO to a USB I'd then boot from the USB, resize the persistence partition to fully use all remaining space on the USB, then copy any user files from the STCK1A8LFC to the USB persistence partition, perform the installation and then copy back the saved user files to the newly created install. You can find more details including the download URL on my blog.
Hello mint13
Thank you for contacting Intel Technical Support,
I received your inquiry and I understand that you are having problems HDMI® audio. Please accept our apologies for any inconvenience this may be causing. I will be more than happy looking for a solution.
While doing a search on the problem that you are having I have found that the Intel® Compute Stick STCK1A8LFC is out of interactive support, you can verify this information on the following link:
https://ark.intel.com/products/86613/Intel-Compute-Stick-STCK1A8LFC https://ark.intel.com/products/86613/Intel-Compute-Stick-STCK1A8LFC
In order to assist you in my best effort, we can try to review if the BIOS is up to date, here you can review the list of BIOS that are available
https://downloadcenter.intel.com/search?keyword=STCK1A8LFC https://downloadcenter.intel.com/search?keyword=STCK1A8LFC
You also may want to review the Ubuntu communities for any driver solution or the following link: https://01.org/ https://01.org/
Leonardo C
Hello Leonardo C,
Thank you for your response to my question. Yes, I understand that this stick is not supported anymore and therefore appreciate any assistance.
My description of the problem clearly indicates errors involving an HDMI audio package and the linux kernel, which doubtlessly is the root of the problem of no HDMI audio. The BIOS is fine (audio worked before updating the Ubuntu 14.04 OS).
I am unable to find a solution on the site you linked to. Of course, I tried to find a solution on other (Ubuntu) forums, and I understand that Linux HDMI support for this stick is not standard, and that some kind of patch is required for the kernel. I was hoping to find someone with such specialist knowledge here, on this forum.
Thanks again.
Hello mint13
We apologize for the inconvenience since you were not able to get a solution on the Ubuntu forum seems that the best way we can proceed to find a solution is with these options:
- Complete OS reinstalled using Operating System Recovery [F8]
- Complete a clean installation of the OS using your own copy of the OS (is recommended to use Ubuntu 14.04)
Leonardo C.
mint13 Have you tried following this guide on linuxium's website?
http://linuxiumcomau.blogspot.com/2017/10/fixing-broken-hdmi-audio.html linuxium.com.au: Fixing broken HDMI audio
Many thanks for your insightful answer. I will try the method that you suggest.
The oem-lts-stacks-installer will update the kernel with working
wireless, but the hdmi sound code fails with a compiler error.
Updating the kernel to versions later than 4.4 has obvious
benefits, but more work than fixing a compile error.
There is a mismatch between the prototype of pin_eld_notify in
/usr/src/linux-headers-4.4.0-116/include/drm/i915_component.h
and the function call in the intel_audio.c file supplied in the
/usr/src/chestersmill/oem-hdmi-audio.deb.
The intel_audio.c code for kernel version 4.4.0-116 at
https://elixir.bootlin.com/linux/v4.4.116/source/drivers/gpu/drm/i915/intel_audio.c
matches the intel_audio.c code, not the linux_headers-4.4.0-116
prototype, so simply editing the i915_component.h file to
remove the extra argument (pipe) allowed the code to compile, and the
dpkg -i command to successfully install the new i915.ko module. This
new module allowed the hdmi audio to work.
No claims are made that the above is a correct fix, but it is a working
fix of the compile problem which allowed a working hdmi sound module to
be built for a STK1A8LFC Intel Compute Stick.
