Intel® Makers
9872 Discussions
No Wifi at startup
PMuld2
New Contributor II
I played with the Wifi setup to make the Intel Edison a Wifi Access Point.
Now, I want to undo my configuration, but I can't make it work anymore. I can login via USB and serial communication.
First, I tried to run ifdown and ifup, but this gives:
root@eddie:~# ifdown wlan0
ifdown: can't open '/etc/network/interfaces': No such file or directory
(why would this not work on the Edison?)
Then, I saw during boot, that I should run:
root@eddie:~# systemctl status -l wpa_supplicant.service
This gave me:
Oct 18 14:30:35 eddie wpa_supplicant[184]: Successfully initialized wpa_supplicant
Oct 18 14:30:35 eddie wpa_supplicant[184]: nl80211: Driver does not support authentication/association or connect commands
Oct 18 14:30:35 eddie wpa_supplicant[184]: Could not read interface wlan0 flags: No such device
Oct 18 14:30:35 eddie wpa_supplicant[184]: wlan0: Failed to initialize driver interface
Oct 18 14:30:36 eddie systemd[1]: wpa_supplicant.service: main process exited, code=exited, status=255/n/a
Oct 18 14:30:39 eddie systemd[1]: Failed to start WPA supplicant service.
Oct 18 14:30:39 eddie systemd[1]: Unit wpa_supplicant.service entered failed state.
Now, I can configure wpa_supplicant (btw, what is that), with configure_edison --wifi
Wifi will work, but a bit more background how to make this automatically during boot would be nice.
Thanks!
Sergio_A_Intel
The ifup and ifdown will not work on the Edison. The Edison's image is based on Yocto and has other features to allow you to change the interfaces configuration. There isn't a /etc/network/interfaces file in the Edison's image. You can see more information on the interfaces if you look at /etc/wpa_supplicant/wpa_supplicant.conf.
I'm not following that last part; the error you posted is the output of running systemctl status -l wpa_supplicant.service? And what is your goal, to have Wi-Fi enabled automatically after boot? To have Wi-Fi enabled after boot you need to go through the steps in configure_edison –setup and have the latest image, what image are you using, what version?
Sergio
PMuld2
New Contributor II
I had the Edison acting as Access Point (Wifi "provider") where I could connect e.g. with my phone.
Now, I want to have the Edison working again as consumer of Wifi, so, removing the Access Point settings. Indeed, when the device boots it should connect to the latest wpa_supplicant network.
Indeed, I tried to flash to the latest image (intel-iot), this results in:
uname -a
Linux edison 3.10.17-poky-edison+ # 1 SMP PREEMPT Wed Aug 20 16:09:18 CEST 2014 i686 GNU/Linux
Is there another option to see what image is installed?
Sergio_A_Intel
Use the command configure_edison –version. The latest version should output 159.devkit.
Sergio
PMuld2
New Contributor II
Thanks, actually I get no version:
root@edison:~# configure_edison --version
Incorrect input. Redirecting to --help
Interactive configuration options:
(none) Goes through changing the device name, password, and wifi options.
--name or -n Changes the device name
--password or -p Changes the device password
--wifi or -w Changes the wifi options
Non-interactive configuration options
--changePassword Changes the device password to the following argument
--changeName Changes the device name to the following argument
Other options
--help or -h Displays these help options
--server Starts the server (testing only)
On an older Edison Image, I remember to had 124 iirc.
PMuld2
New Contributor II
With this same image, I currently get also errors on configure_edison --wifi
Configure Edison: WiFi Connection
Failed to connect to non-global ctrl_ifname: (null) error: No such file or directory
0 : Rescan for networks
1 : Manually input a hidden SSID
Enter 0 to rescan for networks.
Enter 1 to input a hidden network SSID:
Sergio_A_Intel
If the output of configure_edison –version is not 159 then you are not using the latest version. I'd suggest you to re flash your Edison with the latest image using the Flash Tool Lite. https://software.intel.com/en-us/articles/flash-tool-lite-user-manual IoT - Flash Tool Lite User Manual | Intel® Developer Zone
The latest image can be downloaded here http://downloadmirror.intel.com/25028/eng/edison-image-ww25.5-15.zip http://downloadmirror.intel.com/25028/eng/edison-image-ww25.5-15.zip
Let me know your results.
Sergio
PMuld2
New Contributor II
Thanks, Sergio.
I am trying, but as I am on MacOS it is a bit hard.
I tried on the Edison: "reboot ota", and at least the image was restored, I get now
120
But unfortunately, the Edison does not show up as USB device, i.e. with ./flashall.sh the USB ID is not seen:
USB_VID=8087
USB_PID=0a99
TIMEOUT_SEC=60
hmm... I am thinking how to copy the files to the board with another approach, but not sure.
PMuld2
New Contributor II
* new learnings: I need to make sure that both USB cables are connected
* flash lite tool shows edison then, but dfu-util -l not yet
* now trying to copy files via mounted drive
PMuld2
New Contributor II
Yes, it worked now!
With 2 USB cables, copying files to a drive EDISON_F32 was possible as discussed in http://www.helios.de/heliosapp/edison/index.html# Flashing_latest_Intel_Edison_fir http://www.helios.de/heliosapp/edison/index.html# Flashing_latest_Intel_Edison_fir
Then /sbin/reboot ota did work fine:
Poky (Yocto Project Reference Distro) 1.7.2 edison ttyMFD2
edison login: root
159
