Community
cancel
Showing results for
Search instead for
Did you mean:
mrich4
[No audio input] USB SoundCard
Jump to solution
I have an issue to configure my edison to capture and stream audio. I use Ubilinux on Intel Edison. I install alsa
First I plug an USB SoundCard, a generic model with an USB OTG.
I found it quickly :
"lsusb" ->
Bus 001 Device 002: ID 0d8c:0014 C-Media Electronics, Inc. <-- This is my device</span>
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
I try my first "speaker-test"
No sound, so i check my /etc/asound.conf, This files does not exist.
So I do "aplay -l" ->
card 1: Device [USB Audio Device], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Subdevice # 0: subdevice # 0
My "cat /proc/asound/cards"
0 [Loopback ]: Loopback - Loopback
Loopback 1
1 [Device ]: USB-Audio - USB Audio Device
C-Media Electronics Inc. USB Audio Device at usb-dwc3-host.2-1, full speed
On my /usr/share/alsa/alsa.conf, I change c
defaults.ctl.card 1
defaults.pcm.card 1
Now, When i open alsamixer, it show me my mic and headphone volume. Great...
But I do again a speaker-test: again Playback device is default
I create my /etc/asound.conf with :
pcm.!default {
type plug
slave {
pcm "hw:1,0"
ctl.!default {
type hw
card 1
Finally, I try to record with
arecord -d 10 /tmp/test-mic.wav, // record raise my no issues
but
# aplay hw:1,0 -d 10 /tmp/test-mic.wav
Playing WAVE 'hw:1,0' : Unsigned 8 bit, Rate 8000 Hz, Mono
[ 578.725491] 2:1:1: usb_set_interface failed (-22)
I don't find the solution in other discussions .......
Thank you for your help !
Tags (1)
Community Manager
Hello maathor,
Thank you for interest in the Intel® Edison Breakout Board.
I have to inform you that Ubilinux on Intel Edison is out of the support of this technical support team.
In order to receive the appropriate assistance, please send an email to Emutex's technical support team (mailto:support@emutex.com support@emutex.com).
Have a nice day.
Andres V.
Community Manager
Hello maathor,
Have a nice day.
Andres V.
mrich4
I finally try with poky, works : install and play... thanks you !
