Intel® Makers
9881 Discussions
No firmware version number
勇eric
Those days i downloaded the latest firmware iot-devkit-prof-dev-image-edison-20160606.zip and flashed that firmware,
But i found out there was no version number if i run configure_edison --version.
Is this a bug or not it's because something get wrong when i flash that firmware?
I think the i met this problem before when i flash another firmware.
so in the final, it will show up that message like that
Eric
Community Manager
There's nothing wrong with the image itself and there's nothing to worry about, this is normal.
With the latest image, the recommended way to check the image version is using the command cat /etc/version. It should display 201606061707
-Sergio
Community Manager
-Sergio
