Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
No output on new out of the box ComputeStick STK1AW32SC
There is no HDMI output from a new out of the box ComputeStick to an HDMI display. Switched ports on the display, used a different display, used the HDMI dongle and a second dongle. Nothing. Powered and turned off and re-powered the device and still nothing. What am I doing wrong. Isn't it supposed to light up out of the box?
AlHill
Are you using the power adaptor that was provided with the stick?
Doc
Community Manager
I am using the adaptor that was provided with the stick. I inserted the stick into a PC monitor with an HDMI interface and everything worked. Seems to be a compatibility issue with the Sony TV.
AlHill
It could well be a compatibility issue. Glad you have it working.
Doc
Community Manager
Hello:
Thank you very much to Al hill for the comments posted above.
To WMS:
We are glad to hear that the stick is working fine now, the compatibility problem are difficult to detect at the beginning, only by testing the product on a different device will let us know for sure.
Any other inquiry, do not hesitate in contact us again.
Alberto
