Community
cancel
Showing results for
Search instead for
Did you mean:
NHoeh
No putty login
Jump to solution
I want to use putty for my Intel Edison, but after I open the serial terminal and press enter nothing happens
Please help, thanks
NHoeh
Sorry for the long delay. I found out that the problem was that I was choosing the wrong comm port. Thanks for your help
Community Manager
Hi nick13579,
Could you please take a screenshot of the Device Manager? I'd like to check if the COM ports appear. Make sure both USB cables are connected to the board.
Have you used the Edison in other ways, for example from the Arduino IDE?
Diego
NHoeh
