I am trying to debug application through openOCD and gdb on intel galileo gen2 board.
I am able to set the software break point but, program running on hardware is not stopping at that break point.
And If I set the hardware break point then I am sometimes able to stop the code on hardware but not always. Success rate is once in ~10 trial.
I am using below board and architecture:
Hardware: intel galileo gen2 board
processor: Quark X1000
debugger: ARM-USB-OCD-H
Steps I follow is as below:
Create a simple application in the local machine for ex. counter.c:
# include
# include
int main(void){
int num ;
while(1)
sleep(2);
num=num+1;
printf("number = %d\n", num);
return 0;
Compile it with the sdk generated by bitbake using below command:
${CC} -g -O0 counter.c -o counter_app
Copy this binary to board
Run application on board by simply running ./counte_app
Run openOCD by running below command:
openocd -f ./tcl/interface/ftdi/olimex-arm-usb-ocd-h.cfg -f ./tcl/target/quark_x10xx.cfg
Open GDB and connect GDB to openOCD
halt the board and load the symbolic information of application in gdb by below command:
symbol-file /counter_app
After that I have set the break point on line 11 by
<pre __default_attr="xml" __jive_macro_name="code" class="jive_macro_code _jivemacro_uid_15000323566907582 jive_text_macro" data-renderedposition="791.421875_8_1640_16" jiv...Link Copied
Hi Drashti,
Thank you for your contacting us. The best place for you to get assistance in cases where the issue is related to the Quark X1000 is here: premiersupport.intel.com . Please open a new service ticket here so that the experts can help you with your request.
We appreciate your understanding.
-Sergio A
