Intel® Makers
9881 Discussions
OPKG problems with new image release
PMora5
Hi community,
I flashed the newest available image on Intel's website https://software.intel.com/en-us/iot/hardware/galileo/downloads IoT - Intel® Galileo Board Download | Intel® Software and had a problem while updating opkg. Here's what I got:
Does anybody know what script opkg update run? So I can change those links for working ones.
Community Manager
Hello PaulaK,
The issue might be related to the repo configuration, I suggest you to check this thread: https://communities.intel.com/message/393752# 393752 https://communities.intel.com/message/393752# 393752, in it I explain how to configure the repo correctly.
Let me know if this information helps you, I'll be glad to help you if otherwise.
Peter.
Community Manager
Hello PaulaK,
Peter.
PMora5
Hi Peter,
The provided information was very helpful. I've changed iotdk.conf and mraa-upm.conf to clone from 3.0 repository, and it all worked as expected.
I've noticed that this new image supports java and comes with nano, is that correct?
And is it eglibc? (it has a ld-uClibc.so.0 file inside /lib directory)
Many thanks for the prompt reply.
PaulaK
Community Manager
I'm glad to hear that my previous suggestion was of help. If you are using the image found in https://software.intel.com/en-us/iot/hardware/galileo/downloads, then yes, it is indeed eglibc and as you mentioned it now includes by default Java and Nano.
Again, I'm glad to help.
-Peter.
